Author Topic: '82 CB650 weak starter  (Read 554 times)
Offline Z-MO
« on: October 15, 2013, 03:15:13 PM »
So I am helping out a buddy with his CB650.  He hadn't run it in about two years.  We put a new battery in it and the starter sounds weak like its not getting enough juice.  We put the charger back on and let it sit overnight, same thing.  I jumped the starter solenoid to see if that would speed it up a bit but no avail.  Anybody have any suggestions as to the next step?  He is popping a fuse for "meter/taillight" that we haven't chased down yet.  could that be a cause?  Electrical is my weakest area of knowledge with these bikes, any advice would be much appreciated.  TIA.
'75 CB750 Chop
'72 CB750 Cafe
Offline tomkimberly
Re: '82 CB650 weak starter
« Reply #1 on: October 15, 2013, 07:47:16 PM »
Do the basics, check and clean all connections and grounds.
Tom
Offline Rgconner
« Reply #2 on: October 16, 2013, 07:38:59 AM »
Yep, probably voltage drop across dirty contacts or burnt/broken wire.
Try taking voltage readings at each junction, see if it is still 12.6V or has it dropped?
Voltage went into my key lock at 12.6, came out 9ish. Had to clean up the internal contacts to get it back up to 11, ended up doing a relay bypass.
1975 CB550K aka "Grease Monkey"
Offline MiGhost
  • What was that about being an
« Reply #3 on: October 16, 2013, 08:44:58 PM »
A weak starter is often due to carbon dust buildup, and worn brushes inside the starter. Pull it apart, clean it, lube it, and replace the brushes if need. Also check all the cable connections for proper contact, and resistance. The cable that runs from the solenoid to the starter can get pinched causing the wiring inside to break down leading to a high resistance short.
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
Offline trueblue
« Reply #4 on: October 17, 2013, 03:44:37 AM »
Hook a jumper cable direct to the terminal on the starter, if it spins up easily, the problem is in the wiring on the bike.  If it is still lazy, it is the starter ;)
1979 CB650Z
