Author Topic: Trad's 74 CB550 K0  (Read 107747 times)
Re: Trad's 74 CB550 K0
« Reply #525 on: May 14, 2016, 08:21:52 AM »
I just gave my best attempt at measuring my mounted lines -- not so easy when the snake up behind the headlight bucket.  Mine look like they are 35" too.
Offline Trad
« Reply #526 on: May 15, 2016, 08:53:53 PM »
Yeah, it seems that length is almost perfect when running clip on bars.  Not too much slack but enough to turn the bars comfortably without stressing the line.
The brake parts came in Friday night so I assembled it all. Just need to add fluid and bleed the system. In the time waiting for parts I stripped the powder coat and polished the brake calliper. Kind of with I left it black now after seeing it installed. Too much raw aluminium up front? I may take it off the fork and re-coat it black.
May 15 -1 by Jared Chilko, on Flickr
May 15 0 by Jared Chilko, on Flickr
May 15 1 by Jared Chilko, on Flickr
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline jaycox
« Reply #527 on: May 16, 2016, 04:13:52 AM »
I agree, black might look better.
Offline flatlander
« Reply #528 on: May 16, 2016, 05:43:58 AM »
paint it black :)
« Reply #529 on: May 16, 2016, 10:17:49 AM »
I would recommend powdercoat over paint.  A drop or two of brake fluid will eat off any normal paint, whereas the powdercoat is pretty resistant to stains and solvents.
Something I learned the hard way.
Offline b.linden
« Reply #530 on: May 16, 2016, 11:14:39 AM »
Hey, nice build! noticed you didn't use the "bent" washers on the sprocket bolts on the rear hub, did you just use thread-lock or nylon nuts or something? is that enough to replace the washers?
Offline Trad
« Reply #531 on: May 16, 2016, 06:39:23 PM »
Thanks for the input guys. It was black powder coat to begin with and out of boredom I stripped it all away and polished the calliper. I tend to do things like this far too often, it was perfectly fine black. haha Ah well, I'll leave it for now as I got ancy and filled/bled the system.
Cal, there is so much raw alloy on this bike, the polishing ferries are gonna quit. I'm welcoming the oxidization, give it some age.
b.linden, Thanks. I used lock washers and a dab of green loctight. I've done it before and I'll do it again. Never had an issue.
« Last Edit: May 16, 2016, 08:49:23 PM by Trad »
« Reply #532 on: May 16, 2016, 08:09:07 PM »
I like the polished caliper. Leave it!
Offline Trad
« Reply #533 on: May 19, 2016, 11:38:39 PM »
Thanks Steve. Going to keep it raw for now at least, or until the next time I need to do something major with the brake system.
I ordered and installed 110 main jets from Sirius here in Canada. I was unsure of the the brand of 110's I originally installed so it was just for reassurance. I've heard great things about brass from Sirius so I figured I'd try my luck as 110 Keihin press fit secondary main jets are now obsolete. For the 627B carbs (and many other models) anyway.
Also mounted the 5ohm Dyna coils with cleaned up factory brackets and new hardware. These mount in just by re-orientating the factory mounts and adding small spacers between the blocks and the mount on the coil. The spacers just helped keep everything parallel.
110 Jetting by Jared Chilko, on Flickr
74 Carbs 1 by Jared Chilko, on Flickr
Dyna Coil Mount by Jared Chilko, on Flickr
Offline Trad
« Reply #534 on: May 20, 2016, 11:29:12 AM »
Cal,
You're totally right. I wanted them forward like the stock configiration but the backets didn't want to line up as well for me that way. I forgot to remove the paint on the upper left frame hole anyway so I'll grind that off and give it another go.
Offline Trad
« Reply #535 on: October 19, 2016, 02:27:30 PM »
No updates in ages. Been busy riding/traveling/family stuff.
Chopped the rear indicator mounts off the multi-brace. Fit the battery and m-unit; just trial and error planning harness routing.
Swapped Progressive shocks out for some 2810 dampening adjusting Hagons and made a new plate mount out of a small chunk of allow on a sheetmetal brake.
Mark is wresting with pulling out all the corroded studs on the block. Excited to see the bottom end finished up.
Oct 16 3 by Jared Chilko, on Flickr
Oct 16 1 by Jared Chilko, on Flickr
« Reply #536 on: October 19, 2016, 03:26:25 PM »
looks good!  are you routing a LED down to light your plate?  Lots of police tend to look for ticket items on bikes that are throaty in a stop.  Often they don't give you a fix it ticket but a pay this and fix it...  Some of that depends on your attitude and actions.
David
Offline Trad
« Reply #537 on: October 19, 2016, 04:08:07 PM »
David
Hey David, Thanks man.
No Led's on the tag plate. This bike in crazy minimal and is lacking worse violations; Accepting total responsibility.
Honestly, here in Edmonton it's pretty damn Redneck. Tickets I've got have mostly been exhaust related with the un-baffled carpy pipe on my other two 550's. Cops are usually pretty curious about these old bikes and when they see nice ones tend to look the other way if you're a nice guy to them. haha
The bike is registered as an antique so I just say they bike came factory without............
« Last Edit: October 19, 2016, 04:09:54 PM by Trad »
« Reply #538 on: October 22, 2016, 02:25:46 PM »
Trad sent you another pm.
True for up to what? '68... on some small hondas.
Heck by '81 they were the ugly square jobbies...
I liked the '74 small reflector bodies and lenses...they started going bigger due to regs and by '77 they had those awful huge reflectors built into the front fork stalks on huge tubes...I find them ugly.
David
Offline Trad
« Reply #539 on: October 23, 2016, 02:41:32 PM »
David
Hey David,
Replied to your PM.
I believe it's true up to late 60's Hondas but most cops don't know that. The bikes look old so they usually go along with my assertions.  ;D
The next bike I want to build will be a factory correct resto, with the OEM indicators throughout. I agree 100% with you; It's got to be pre 77 for that. :P
« Reply #540 on: December 31, 2016, 01:02:56 PM »
Happy Birthday, Jared.  8) 8) 8)  Now that it's too damn cold to ride in your neck of the woods, let's see some work on the bike!  ;) ;D
Offline BLAC
  • An espresso is a
« Reply #541 on: January 06, 2017, 09:25:49 PM »
I agree! I like following this build!
Also, we spoke about a cam a while ago right? You aren't still selling one are you? I decided to build my motor..  ;D
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
« Reply #542 on: January 07, 2017, 12:25:29 PM »
Hey Jared,  Sorry for the belated greeting...Happy Birthday and Happy New Year!  Hope the Christmas was good for the wife and kids, you too! ;)
When's the new little one due?
David
Offline firebane
« Reply #543 on: March 11, 2017, 05:50:21 PM »
Just found your thread. I am from down in Calgary working on a 76 550f. Enjoyed what you did and will have to check out the yards up there for some stuff.
