Author Topic: '78 750A loom ground  (Read 2733 times)
Offline Wavecutter
« on: October 30, 2013, 04:32:12 PM »
The ground to frame on the left side (which I assume from reading the forums and the schematic is the loom ground) is still attached to the
frame but I've forgotten where it connected to since I replaced the old harness. I'm hoping someone might be able to direct me. I think it is my last hurdle. Thanks.
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: '78 750A loom ground
« Reply #1 on: October 30, 2013, 04:48:09 PM »
Pretty sure about this - front bolt of the coils, left side.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
  • Moderator
« Reply #2 on: October 30, 2013, 04:56:42 PM »
Scroll down for a pic of the ground location.  I know this is an F bike - but it is the same as on my A.
http://forums.sohc4.net/index.php?topic=91100.0
Offline Wavecutter
« Reply #3 on: October 30, 2013, 05:48:37 PM »
From what I've read these things are close to the tank? Mine mounts low near where the swingarm bolts to the frame at the bottom. I've circled the
flange that I need to connect with something. The other end is bolted to the frame just a few inches away. It's about foot and a half
long.
  • Moderator
« Reply #4 on: October 30, 2013, 06:35:27 PM »
that looks like the battery ground - not the loom ground.  The end you've circled goes to the battery negative connection.  The other end should be a round ring, and goes in between the engine and the frame, right side - back/upper engine mount.
Offline Wavecutter
« Reply #5 on: October 30, 2013, 06:39:36 PM »
My battery negative is on the right side. This is on the left.
  • Moderator
« Reply #6 on: October 30, 2013, 06:48:06 PM »
then the only option then - is that is the starter power cable - and should go to the starter solenoid.
Offline Wavecutter
« Reply #7 on: October 30, 2013, 07:32:45 PM »
That was my suspicion. So it bolts to the frame and which terminal of the solenoid?
Offline Wavecutter
« Reply #8 on: October 30, 2013, 07:44:56 PM »
I'm confused. I need to go have another look at it but I'm pretty sure this thing is bolted to the frame. I'll drop in on friday or saturday to where I have it stored.
  • Moderator
« Reply #9 on: October 30, 2013, 07:59:28 PM »
The solenoid has two large cables.  One goes to the battery, and the other goes to the starter (which is hidden under a cover on the left side of the motor).
If the other end mounts to the frame, then it is the negative for the battery.  There aren't any other large ground wires on a stock A bike.
If you've got something else, it doesn't appear to be stock.
« Last Edit: October 30, 2013, 08:14:13 PM by kandrtech »
