Author Topic: CB350f slightly modded hot rebuild.  (Read 2449 times)
Offline IBleedHondaRed
    • OEM Parts diagrams from my shop
« on: February 04, 2014, 11:59:55 AM »
i have 2 '73 cb350f's. one was my first motorcycle that came from my granddad and the other was picked up in virginia beach early one summer morning headed to the oceanfront to go surfing. it was in a guys front yard and he wanted it gone. title in hand for free. figured that was a good price for a complete bike with a title and 8,000 miles. it had a blown head gasket and looked beaten by the weather. i also have 2 other engines i can use for parts.
i removed the engine and tore it down to the cases and labeled everything. im going to polish the covers up and painting the cases and other surfaces. i want to return the one my granddad gave me to stock, like it did when he had it and then cafe the other and rod it out a little.
i have no intention of winning races or building it for anything other than riding on a sunny day and my gf having something to ride when i ride my 71 cb500 cafe. but i do want to have some fun with it since im pulling it down anyways. i do not wish to bore it or do any head work to it but would like to do a new cam, oil cooler, electronic ignition and new 3 ohm coils as i robbed the coils to replace the ones on the other bike
plans:
1. Camshaft
2. All new oil and valve seals and engine gaskets (acquired)
3. Dyna S electronic ignition and 3 ohm coils
4. Oil cooler
5. Maybe new valve springs
Here are my questions
1. recomendations on WebCams grind #302 and grind #3 (requires new valve springs)
4. are there any kits out there for an oil cooler on these bikes or am i on my own?
5. would it be worth it to do new valve springs even on the #302 grind or am i over building the engine for my requirements?
any assistance here will be well received. its always good to get some other opinions before a build
OEM DIAGRAMS http://www.shopstarcitypowersports.com/OEMpartfinder.htm
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
1989 Hawk GT 647 (Adventure)
1989 Hawk GT 696 (Barely street legal track bike)
2007 XT225
2008 650 Gladius
2012 CB1000R
2012 VT750 Phantom   SER #000105
2013 F6B Goldwing      SER #000082
2013 KTM 300 XC-W
2014 CTX 700             SER #000043
Re: CB350f slightly modded hot rebuild.
« Reply #1 on: February 04, 2014, 12:05:01 PM »
do i need a new camshaft sprocket?
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
2007 XT225
2008 650 Gladius
2012 CB1000R
2013 KTM 300 XC-W
« Reply #2 on: February 04, 2014, 12:07:42 PM »
New/stronger heavy duty valve springs will help keep you from floating a valve into a piston head. If you don't miss a 1 to 2 powershift at redline you could be OK but I recommend replacing them for cheap insurance especially with a high performance cam. Been there done that.
« Reply #3 on: February 04, 2014, 12:31:54 PM »
i guess i was a little misleading there. i am planning on porting and polishing the head but i have no intention of doing oversized valves or getting a 5 angle valve job done. seats all look good, already have a package of new seals, and 3 sets of parts to choose from. looks like ill be salvaging 3 rocker arms from the other two engines
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
2007 XT225
2008 650 Gladius
2012 CB1000R
2013 KTM 300 XC-W
« Reply #4 on: February 04, 2014, 12:35:56 PM »
how about doing a regrind vs. a hardweld?
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
2007 XT225
2008 650 Gladius
2012 CB1000R
2013 KTM 300 XC-W
« Reply #5 on: February 04, 2014, 01:01:21 PM »
If you can buy a cam outright then don't waste your time or expense on regrind or hardweld. A cam is pretty much a cam. If you can't find a new cam then you can send in a stock cam etc and have those things done to it but it will probably cost you more.
« Reply #6 on: February 04, 2014, 01:21:25 PM »
was planning on using webcams as i am a dealer for them. you have to send them a core. will cost me about 225 for a hard weld or 140 for a regrind but then you have to adjust the valves to account for the difference. i have yet to see a company that sells them outright
Opinions on 3 ohm vs 5 ohm coils on the 350?
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
2007 XT225
2008 650 Gladius
2012 CB1000R
2013 KTM 300 XC-W
« Reply #7 on: February 04, 2014, 03:34:18 PM »
I was going to echo the post about porting, but you have it covered.  With the port and polish and a cam, you should get an uptick in performance.  I think that your best gains will be to reduce weight as much as possible.  Strip the bike of anything that is not necessary, and replace as many heavy parts with lighter ones (replacing where possible steel with aluminum or other lighter materials).  If you can find an aluminum gas tank and seat, that should help.  Almost any fiberglass seat will reduce the weight, too.  I would also ditch the center stand and replace stock parts with mini-coils, aluminum rims, digital gauge, airbox, etc. to shed some weight.
« Reply #8 on: February 05, 2014, 06:24:49 AM »
How much we talkin here? and my other question is why did you decide you needed 5 ohm coils? i read the paperwork that came with dads dyna setup it says 5 ohm coils are recommended for points breaker ignitions.
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
2007 XT225
2008 650 Gladius
2012 CB1000R
2013 KTM 300 XC-W
« Reply #9 on: February 05, 2014, 06:25:22 AM »
pm me
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
2007 XT225
2008 650 Gladius
2012 CB1000R
2013 KTM 300 XC-W
Offline 2strokeTrush
  • Can you get that back together sonny?
« Reply #10 on: February 06, 2014, 12:09:42 PM »
get some pictures up, im in the middle of a 350f build to
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
Offline BCBarker
  • Hey
« Reply #11 on: February 06, 2014, 12:29:44 PM »
you should be able to use a CB750 oil cooler adapter like these. same size as on the CB350F i believe.
http://www.cyclexchange.net/Oil%20System%20Comp%20Page.htm
