Author Topic: Another Urban Myth Debunked  (Read 4912 times)
Offline tbpmusic
« on: February 15, 2014, 10:21:32 AM »
Wanted to relate my experience recently.........
Offered solely as information based on hands-on experience, not some anecdotal blathering from someone on a website.
I rebuild a lot of 450 engines, among other problems I see a lot of failing torsion bars on CB/CL 450's now.
Not surprising, they're all pretty old now. Worse yet, many of  these bikes have been sitting for years, and invariably one or more valves is open as it sits. Like any spring, torsion bars need to "relax" once in a while, or they don't spring so good any more.
New or even better parts are unobtainium, so I decided to investigate the torsion bar "trick" I've heard people relate for decades.
The suggestion is to grind off one of the splines adjacent to the "key" on the torsion bar so it could be rotated further, increasing the pre-load required.
It's fairly obvious to me now that none of those people have actually tried it, they're all blowin' smoke.
I chose to modify the outer "sleeve" portion of the torsion bar setup, where the crows-foot piece  (it contacts the underside of the valve retainer thing) goes on - it's splines are larger and the material isn't too hard to Dremel off.
The photo shows a 2-piece 5-speed torsion bar. The 4-speed 450's have a 3-piece torsion bar that's a major pain in the butt to install, it keeps falling apart. But the two will interchange directly.
The skinny inner part (the actual torsion part) has the same number of splines, but they're much smaller, and that stuff is HARD.
There are 19 splines on the torsion bar's outer "tube" - that means jumping one spline is almost a 19-degree rotation - that's WAY too much, something like 5 degrees would work.
On a really bad torsion bar I have, the preload (torque required to get it up get it up on its knock pin) jumped from ~5 INCH-pounds to well over 15 FOOT-pounds.
Honda's spec in the manual is 4.5 ft./lbs (54 inch/lbs.) so this is NOT an acceptable solution.
That's so freakin' tight the torsion bars are sure to self-destruct in short order, and the valves would be hammered unmercifully till things broke.
The only real long-term solution is to convert to valve springs, and that's pricey.
Wandering a little-
Valves and valve seats are already an issue with 450's - the early 60's materials used can't stand up to unleaded fuel.
The more unleaded miles the bike has, the worse the damage seems to be. Without the "cushion" of the lead additive, the seats just get pounded away, receding further until the valve protrusion becomes an issue. And it doesn't do the OEM valves much good either.
This issue is common among all old engines, not just old Hondas.
On a 450, valve protrusion is critical, affecting the tappet adjustment range as well as torsion bar preset.
Worse yet, if the seat geometry is re-establised by "cutting" the old seats (and assuming protrusion isn't mucked up), you'll get maybe 10,000 unleaded miles until things go south again.
The real solution is brand new seats and valves, made of modern materials (MUCH harder) actually designed for the fuel we have.
Fortunately I have a buddy with a machine shop, actually a Harley/sprint car speed shop. Something about the old twins piqued his interest, and  he tooled up to do a lot of stuff for me.
One thing we've done is to work out the details of totally replacing the valve seats with modern stuff.  We've also laid in a small stock of Capelini 7mm stainless valves.
With modern seats and stainless valves, it will last a very long time with no leakage. He also does boring, bronze oversize valve guides, porting/flow, dyno work, etc.
I have a spare 5-speed head here that already has the new valve seats, saving my sheckels for a spring "kit" - those all require a switch to 5mm valves. Barring the spring kit, I'll at least put in the stainless 7mm valves.
I hope to switch it all out on my daily rider someday.
Bill Lane
Offline strynboen
Re: Another Urban Myth Debunked
« Reply #1 on: February 15, 2014, 10:33:25 AM »
i have a  1976 500  t..engine..is that updatet..vith better valve/seats/guides...is it cast  "only"aluminium ....not casted l cone in the head..and higer compresion
i hate all this v-w.... vords
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #2 on: February 15, 2014, 11:26:04 AM »
       Ah Bill, leave it to you, to try to come up with a way, to keep the old 450s going, eh?  I TOO, would like to see the 450s be able to be updated enough to keep them on the road. So, what kind of cash, are we talking (approximately)? I would have to do like you, and save up most likely. Mainly, my interest would be for the 3 '74 450s I have (1-CL and 2-CBs) Knowing you, as I do, I know that you go into something like this, with research and knowledge and I can appreciate that. Now, I have to wonder, like "stryboen" has asked, would the later model 500 heads be any better? Or would you be facing the same issues?
Member # 1969
Markcb750
« Reply #3 on: February 15, 2014, 11:33:04 AM »
Nice write up, Thanks
I am doing a resto-mod on a near scrap 67K0 450.  Motor has indicated 6800 miles. Photo provided for amusement.
Number one intake valve must have been just cracked open during the 29 years the bike sat under a shed roof because only it leaks solvent when the chamber is filled.
Long story... ::)
If I sent my head to your friend, do you have a ballpark price?
Do you know of a source for the valve tension tool described in the 450 Shop Manual?
Offline tbpmusic
« Reply #4 on: February 15, 2014, 06:54:21 PM »
BH-101 Bore and hone one cylinder up to 0.020" (~2'nd over) $50.00
BH-102 Bore & Hone one cylinder, 0.030" to 0.060" $75.00 (more passes on the boring machine)
CHV-100 Grind valve, each $7.00 (He HATES doing this - with a new seat and valve, no lapping is required)
CHV-101 Install new valve seat, each $75.00
CHV-113 Cut three angle valve seat, each $35.00 (existing or new seat)
Prices are labor only
T-215 Valve Seat, 1.340", 1-1/16", .200" $10.99 each
T-269 Valve seat, 1-9/16", 1-1/8", .200" $11.99 each
So, about $125 per valve to replace seats and cut new faces in them.
30-0368 Kibblewhite C63000 nickel bronze Valve guide, Both Intake and exhaust, +0.002", fits Honda® CB 450 1965-1972, each $20.95
CHV-111 Install  and size new valve guide, each $16.25
They are "oversize" in the section that fits into the cylinder head. Over time guides can get loose in the head, much like a loose tooth. They get bored out slightly and the new guide is interference-fit.
All this is available for 350's as well.
I just talked to the machinist, we may have a lead on a manufacturer who is willing to custom make stainless valves for us, cheaper than Capelini.
These prices are all what he charges me, and I get a discount. I do not mark up the cost for my customers.
As for the torsion bar preset torque wrench in the manual, I haven't seen one of those in decades.
I just cut a notch in a deep-well 19mm socket, fits over the end of the torsion bar. Generally the inch-pound torque wrenches are 1/4" drive, so you need an adapter too.
The prices for these valve springs outrage me - $400 for a set, just the springs?!
A valve spring for a Gold Wing is less than $10.
Economy of scale, or shameless profiteering?
« Last Edit: February 15, 2014, 06:56:20 PM by tbpmusic »
Bill Lane
« Reply #5 on: February 15, 2014, 07:22:12 PM »
tbp this is very interesting, I read about torsion springs used in engine Honda heads but this is the best hands on info I seen so far.  Thank you.
Offline bill440cars
« Reply #6 on: February 15, 2014, 08:24:46 PM »
  Gotta say, Bill, you, my friend are Loaded with info or where to get it. Always a pleasure being on a forum with you.   ;)
Member # 1969
Markcb750
« Reply #7 on: February 16, 2014, 06:52:29 AM »
Thanks for the info.
I held a 3/4" impact socket in my hands yesterday, put it down... thought I would give it one more try on the net before I cut the socket.  :(
Thanks
Offline tbpmusic
« Reply #8 on: February 16, 2014, 09:21:58 AM »
Thanks
You can easily see the torsion bar "foot" and it's relation to the knock pin when you use this.
Let us know the readings you get, add to the database.........
« Last Edit: February 16, 2014, 09:24:27 AM by tbpmusic »
Bill Lane
« Reply #9 on: February 16, 2014, 10:16:42 AM »
How many guys need those sockets, could do a nice job of that on the surface grinder.
Offline tbpmusic
« Reply #10 on: February 16, 2014, 11:42:24 AM »
Well, anyone who seriously rebuilds a 450 could use one.
Let's see, that makes about, what - two or three (yuk, yuk).
Bill Lane
Offline tbpmusic
« Reply #11 on: February 18, 2014, 08:44:18 AM »
   ..... like "stryboen" has asked, would the later model 500 heads be any better? Or would you be facing the same issues?
I'll confess to very little hands-on with 500T's. By then I had finished college and moved on, I've given a few of them tuneups, that's it.
The 500T was basically a stroked 450, there's some interchangeability. Apparently the head's combustion dome is different in some way. The 500T's compression ratio, at 8.5:1 is actually lower than the 450. Performance was also below a 450's.
With sluggish performance and looks only a mother could love, the 500T was a flop in the 4-cylinder world of the mid-70's.
I hear anecdotal stuff about 500 heads on 450 engines and vice-versa, never did any of it myself. The valves are the same parts on both models, so it can be assumed the valve seats are as well.
To answer 70CB750, as far as I know, the 450 was the only production Honda bike to use torsion bars. At the time they were a marvel of technology, the whole engine was. Now that all the torsion bars are worn out and you can't find replacements, it's not so marvelous.
But the good thing about the engine is that it will run in even terrible condition, they're tough.
One might lament Honda's decision to merely stroke the 450 engine a little to get the 500T - I do.
Had they decided to expand the 450 concept to a 750 twin, holy cow.......it would still be a killer and desirable engine to this day - though a watershed design (like the CB750 K0 was), today just an interesting footnote in motorcycle history.
« Last Edit: February 18, 2014, 08:47:25 AM by tbpmusic »
Bill Lane
« Reply #12 on: February 18, 2014, 08:55:30 AM »
Would you mind finding it for me on cmsnl.com? I would like to look at some schematics.
Thank you
Offline cheftuskey121
  • Super Newbie
« Reply #13 on: February 18, 2014, 06:47:56 PM »
thanks for the info. going to be rebuilding a 450 engine so this is good info! thanks
