Author Topic: Valve and Valve guide question  (Read 1766 times)
Offline Fatlip
« on: February 26, 2014, 01:39:35 PM »
I have a 1978 CB750k and I am trying to replace my valves,valve springs and valve guides.
 I am having trouble finding Valve train components for this year model that arent super expensive.
I was wondering if anyone knows where i can find them for a decent price.  Also is it possible to use valves/valve guides for the 69-76 models?  is there any difference?
Re: Valve and Valve guide question
« Reply #1 on: February 26, 2014, 02:13:57 PM »
good luck  ::)
You're looking at $300+ right there in parts, not to mention valve seals, valve grind labor, and any other head work you decide to have done.
Cycle Exchange
APE(cbrzone.com)
Dynoman.net
Offline Fatlip
« Reply #2 on: February 26, 2014, 02:49:46 PM »
Well I wouldnt consider $300 to be outrageously expensive. I did find valve springs that are compatible with all the K models for $90.  I just havent seen valves that say they work with the 77-78's that arent 40-50  or more per valve.
Im just wondering whats the difference in the 69-76 cb750k's compared to the 77-78's?
« Reply #3 on: February 26, 2014, 03:13:45 PM »
valve OD is larger
« Reply #4 on: February 26, 2014, 03:17:55 PM »
Aren't valve the same for late F?
« Reply #5 on: February 26, 2014, 04:54:49 PM »
77/78K and F2/3 valves have different part #'s, and isn't the valve keeper config a little different?
« Reply #6 on: February 26, 2014, 06:36:18 PM »
You are right, here is more info:
« Reply #7 on: February 27, 2014, 07:20:08 AM »
Good stuff right there!  Hope that page is in the FAQ's
Offline Fatlip
« Reply #8 on: March 05, 2014, 10:43:21 PM »
Thanks 70cb750, that pic was super helpful. I went ahead and bought a set of valves off eBay from an older model so I can use the valve keepers and retainers.  Much cheaper than the titanium conversion kits most places are trying to peddle.  Thanks fellas.
Offline 74750k4
« Reply #9 on: March 06, 2014, 04:29:06 PM »
That is good info. unfortunately, does not however, include cam info, which also differs, model to model, year to year.
