Author Topic: Partial choke seems to make things run better  (Read 910 times)
Offline gregripko
« on: March 20, 2014, 03:19:33 PM »
Bike runs great but notice it seems to like a tad choke.... Just a smoother throttle response...by partial choke I mean just a tiny crack of it.... What action could I take to ride without partially choking and yet still possibly retain smoothest throttle input? Ty in advance
Cb550k
Offline tomkimberly
Re: Partial choke seems to make things run better
« Reply #1 on: March 20, 2014, 03:22:12 PM »
Clean your carbs and make sure to clean the emulsion tubes.
BTW, are you running the stock air box and exhaust?
Tom
Offline thep1pe
  • Proud Owner 76 CB550F1
« Reply #2 on: March 20, 2014, 04:41:45 PM »
Richen it up a tad. Check for air leaks too.
« Last Edit: March 20, 2014, 04:45:49 PM by thep1pe »
« Reply #3 on: March 20, 2014, 05:26:46 PM »
If you need reduce the air going into the carbs to get smooth running, you have a lean condition. It can be dirty jets, an air leak or a combination of both.
Offline bjbuchanan
« Reply #4 on: March 20, 2014, 07:08:24 PM »
The answer is in your question, just think about it. A choke reduces airflow so if I reduce airflow my air/fuel ratio "seems" to be richer now.
If richer makes me faster, then I was running lean. I'm not d!cking you around just think about it.
Next step is to isolate where the bike runs better, at what throttle position. I have seen you post other stuff identifying things like this with the carbs so go for it
Offline gregripko
« Reply #5 on: March 20, 2014, 09:01:26 PM »
I know that it means I need to run a tad richer... That's sorta common sense... But there's a lot of ways to richen it... Just wondering what's the best way
Offline gregripko
« Reply #6 on: March 20, 2014, 09:04:21 PM »
Btw the bike has been running awesome... Which is why I've been a tad quiet in here
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #7 on: March 21, 2014, 05:54:31 AM »
There is no best way. You need to find out what is making it lean, first.
Dirty jets? Air leak? etc. etc. etc...
--Evan
1975 CB750K "Rhonda"
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: March 21, 2014, 07:48:47 AM »
Fixing the problem as mentioned before would be your best bet. Check for vac leaks. With the bike running, spray some WD40 or starting fluid around the carb boots and manifolds especially where they meet another surface. if the idle changes you have a bad seal somewhere. If that's not it then take the carbs off and go through them with a fine tooth comb, so to speak. And you didn't answer the question on what kind of air intake do you have? OEM, PODs, etc?
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline gregripko
« Reply #9 on: March 21, 2014, 10:00:04 AM »
Foam filter in stock airbox
Offline bjbuchanan
« Reply #10 on: March 21, 2014, 11:28:53 AM »
I told you what to do
Find out where response is better, according to the throttle grip position.
If it is better at idle, play with idle screw 1/4 turn to richen a tad. If further out up to roughly 1/4 then maybe pilot.
If felt across a wider range from almost 1/4 on up thru half it is the needle. Try shimming for a baby step or go one full notch richer.
This is all assuming that everything else has been sorted. If you change the needles your sync that you nailed a couple weeks ago will be lost
