Author Topic: 400f front end gudder  (Read 861 times)
Offline Frenchmike
« on: May 19, 2014, 03:48:06 AM »
Hi one and all, well I still have my front end gudder that I though was the fork oil being to thick, but now I have changed it for ATF its' still the same, but now having checked the front tyre.
( I have noticed the tyre is running out of true, by about 8 mm,
do you think this will give me the same experience.)
I don't want to buy a new tyre if it's not necessary, as the the tread is good. :-[
I have deflated the tyre, loosened to tyre bead and applied so washing up liquid, reinflated it , but it still the same
Offline trueblue
Re: 400f front end gudder
« Reply #1 on: May 19, 2014, 03:57:07 AM »
Look around the bead there should be a bit of fabric equally  visible the full circumference of the bead on both sides. If it isn't equal then your bead isn't seated properly. If it is even then I would suspect a separated tyre, which will need replacing.
1979 CB650Z
Offline krusty
« Reply #2 on: May 19, 2014, 04:27:31 AM »
Have you checked the run out at the rim? If its out then your wheel will need truing, that is spokes correctly tensioned.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline Frenchmike
« Reply #3 on: May 19, 2014, 05:41:30 AM »
Thanks for both replies I'm off out in the garage to check
Offline trueblue
« Reply #4 on: May 19, 2014, 05:44:55 AM »
That too, I keep forgetting that most of these bikes still have spokes.
1979 CB650Z
Offline Frenchmike
« Reply #5 on: June 15, 2014, 04:15:27 AM »
It's me again and I still have the same problem , :-\ so my next question is has anyone changed the RING, PISTON in the forks , that is the small plastic split ring at the top of the internal rod, if so where did you  buy them
