Author Topic: CB750K6 Barn find Chopper - Engine Rebuild and Chassis repairs  (Read 5712 times)
Offline Trikeopath
I've just picked up this 1970's CB750K6 SOHC Hardtail about 2 weeks ago.
It's been with the previous owner since 1984 but other than what he has told me, the origins are unknown.
The motor seized a few weeks ago so I pulled the Head and Barrells off the other night and found No4 Rod has welded it's self to the Crank.
Also does anyone recognise the Frame? It looks straight and very well made. So far I think it's either an Uncle Bunt or Desperate Dan Challenger??
« Last Edit: August 29, 2014, 03:06:14 AM by Trikeopath »
DIAMOND MOB - LAND SPEED RACING -
Somewhere between Murder and Suicide is a place called Merseyside!
Offline Trikeopath
Re: CB750K6 - Engine Rebuild and Chassis repairs
« Reply #1 on: June 05, 2014, 04:09:23 AM »
2nd inspection of the engine has shown up a shattered clutch spring plate and some prizes in the sunp and oil pump.
Offline Trikeopath
« Reply #2 on: June 05, 2014, 04:12:51 AM »
Cam and Top end are perfect. The 2 middle pistons are a bit scored but I can re-bore that myself so no drama.
When opened the rockerbox there was plenty of clean oil up there.
The Crank problem appears to have been human error. I found one of the Mains hammered in backwards so there is no reason why the same fitter hadn't done the same with the Big End, resulting in it spinning....
The Main had one half in the right way so that couldn't go anywhere as easily.
Rods have arrived now so I can get on with matching them to the Crank and start ordering the stuff to do the bottom end.
The shopping list  for the Motor looks something like this:-
Crank & Oil Pump
Gasket set
Con Rods
Main Brg Shells
Big End Shells
Primary Chains
Cam Chain
Primary Tensioner
Guiness
Seals
O/S Piston kits
Vapour Blasting
Offline Trikeopath
« Reply #3 on: June 05, 2014, 04:14:54 AM »
Before I go any further with the Engine I found a few questionable repairs and modifications to the frame.
The Footrests that were on the rear motor mounts had been well bodged about and the Battery box was hilarious.
Old Footrests
L/H Engine Mount (whats going on with the giant lump of weld??)
R/H Engine mount with bodged C90 pedal mechanism.
« Reply #4 on: June 05, 2014, 04:29:33 AM »
Welcome!
Nice project you got going here.  ;D
Offline Trikeopath
« Reply #5 on: June 05, 2014, 04:35:30 AM »
Thanks man, its one of many. I normally have 3 or 4 builds on the go at any one time.
Just ordered a bunch of stuff from Holland to work out the bottom end.
In the meantime I've got some machining to get on with for the Footrests.
« Reply #6 on: June 05, 2014, 04:37:58 AM »
Well, glad you joined  ;D
Offline Trikeopath
« Reply #7 on: June 09, 2014, 05:21:17 AM »
Rear Engine mounts now fixed.
Old half arsed Side Stand looked pretty #$%* so I adapted one off an Enfield.
I made this battery box but it doesn't fit (Oil tank makes it difficult to remove).
Offline Trikeopath
Re: CB750K6 Barn find - Engine Rebuild and Chassis repairs
« Reply #8 on: June 09, 2014, 05:44:53 AM »
Here is the Battery box finished.
As I said, it's no good for this bike but I have managed to donate it someone with a similar frame on another forum.  ;)
Offline Trikeopath
« Reply #9 on: June 11, 2014, 09:13:44 AM »
Machined up a couple of footpegs out of stainless Hex bar. They will also be the nuts for the rear engine mount.
Offline roadgoeson20
« Reply #10 on: June 11, 2014, 12:38:40 PM »
Your machining skills outclass mine.  Nice work.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Offline Trikeopath
« Reply #11 on: June 12, 2014, 02:34:49 AM »
No skills here man.
I just bought a cheap Lathe because I was sick of waiting for other people to make silly parts for me and I'm having a go.
Offline Trikeopath
« Reply #12 on: June 16, 2014, 11:13:32 AM »
Well, I'm on Battery box MK3 here, which has led to Oil tank MK2 and Mudguard Mk2.  :-\
<a href="http://s278.photobucket.com/user/Trikeopath/media/CB750/DSCN09531_zpsf26f69fc.jpg.html" target="_blank"><img src="http://i278.photobucket.com/albums/kk107/Trikeopath/CB750/DSCN09531_zpsf26f69fc.jpg" border="0" alt=" photo DSCN09531_zpsf26f69fc.jpg"/>[/url]
Offline Trikeopath
« Reply #13 on: June 17, 2014, 04:21:22 AM »
I take it there's not too many Chopper guys here then...
I started mounting the Rear brake master cylinder last night, only after welding up the first spacer boss, I realised I'd left the secend one in the lathe at work. Never mind, to be continued....
Offline Trikeopath
« Reply #14 on: July 02, 2014, 09:03:47 AM »
Been messing round with a new rear guard.
Started off with this one that was left over from a Skirty I built the other week.
Chopped off the fat and tightened up the radius.
Added some 5mm round bar as a bead and to add strength.
Notched it out to clear the Battery and re-fitted the piece of frame I cut out when I moved the Battery.
Offline blue collar
« Reply #15 on: July 02, 2014, 11:23:16 AM »
Love it. The foot pegs are boss.
Offline Trikeopath
« Reply #16 on: August 20, 2014, 09:06:42 AM »
The original owner of this CB wanted his new bike modifying so, as the Front end off the CB had a bit of sentimental value, we did a deal last week for it to be fitted to his Dragstar.
The Forks are 160 longer than the Stock Yam set so I made a new Headstock and re-raked the frame with bit more stretch.
The Dragstar front end is now mine and I've put 6" over stanchions in to make it fit the CB frame.
Offline Trikeopath
« Reply #17 on: August 20, 2014, 09:08:01 AM »
Just got the Crankcases back from CRC Restorations in St Helens.
Nice job and much easier than S.O.C, Petrol and a toothbrush.
Offline Trikeopath
« Reply #18 on: August 28, 2014, 03:24:42 AM »
Got the new front end test fitted. The Stem needs a bit of alteration bit it'll work fine.
Also built up the new Crank and started replaceing bearings in the Gearbox.
Offline CBJoe
« Reply #19 on: August 28, 2014, 02:57:11 PM »
Those cases look great!  You said they were vapor blasted?
Cheers, joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline Tews19
  • I am no
« Reply #20 on: August 28, 2014, 06:35:59 PM »
Interesting build! You should PM 754... He a chopper guy and knows all the old school tricks. Subscribed.
1970 Honda CB750 survivor.
« Reply #21 on: August 28, 2014, 08:28:45 PM »
You might try putting something alluding to this being a chopper project in the thread title...that should draw the fans in.
« Reply #22 on: August 29, 2014, 03:45:35 AM »
+1 plenty of chopper fans here including myself and enjoying your progress so far. Dont forget http://www.hondachopper.com/ either.
cheers
Andy
Offline Trikeopath
Re: CB750K6 Barn find Chopper - Engine Rebuild and Chassis repairs
« Reply #23 on: August 29, 2014, 03:59:10 AM »
Cheers, joe
Yes mate. It only cost £90 and they came out really well.
Cheers man, I'm just getting back into reassembling the motor so I'll put more detail of that up as it happens.
cheers
Andy
Done guys. Thought this thread had died on its ass and maybe folks were more into restoration than alteration. This build is a bit tame compared my other projects, so might not attract as much debate.
Offline BPellerine
« Reply #24 on: August 29, 2014, 05:42:20 PM »
you have great fab skills ,adapting the hd brake was a good move.bill
1978 CB 750K ard and webers
another anfob
