Author Topic: Horn suggestions  (Read 2523 times)
Steelo
Horn suggestions
« on: May 23, 2005, 07:29:32 AM »
I want to replace my bike horn with something to wake the bejesus out of some of these meatheads that threaten my life daily. Can the std horn be replaced with a louder horn. Have been looking at some twin 115db Fiamm car horns with a relay. Will these work or does it strain the electrics. Any other suggestions would be gratefully accepted.
Offline gkw120649
Re: Horn suggestions
« Reply #1 on: May 23, 2005, 07:40:13 AM »
Use a horn relay for best results.  Fair simple hook-up.  Refer to the following site.  Not very hard at all.  Good luck.
Greg.
http://www.rattlebars.com/mtz/hornrelay.html
1977 CB-750 K
1978 CB-750 K
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: May 23, 2005, 08:09:44 AM »
I've got the twin Fiamm "Freeway Blaster" horns on my 750.  You can see them in the picture below, mounted where the stock horn used to be.  You do have to use a relay, but it's easy to do and really scares the piss out of the driver of that car coming over into your lane.
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: May 23, 2005, 08:11:20 AM »
Oops!  Forgot the picture, but you get the point...
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #4 on: May 23, 2005, 08:31:20 AM »
I had twin FIAMMs with relay on my 500 in the '70s (see avatar)
They were OK but the relay was not designed to be out in the breeze (read salt-laden, wet blast for UK winter) and did not last very long.  Also the clear plastic tubing that connected the compressor to the horns discoloured and looked sh*t very quickly. The compressor was mounted on the original horn mounts.
They were really REALLY loud.
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Offline Zeke
« Reply #5 on: May 23, 2005, 11:17:27 AM »
I'm going to put some FIAMM disc horns on my bike -- 130db.
Look at JC Whitney under motorcycles > horns and you'll see them -- I've heard they are frightening.
Zeke
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #6 on: May 27, 2005, 08:05:54 PM »
I replaced my horn with open pipes, and, the little four makes  more noise than a twin.. It is fun around town ( on the highway it is ridiculous). Seriously,   I have noticed that the "cage drivers" as they have been refered to in other posts, have taken notice to my proximity(sometimes begrudgingly) but none the less... i think there may be something to the "loud pipes save lives" mantra...
 Air horns are probably  more practicle....
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
