Author Topic: Paint Disaster  (Read 4241 times)
Offline nvr2old
Re: Paint Disaster
« Reply #50 on: August 27, 2014, 08:42:47 AM »
I've painted 100's of gas tanks, and the one thing you have to do is seal the tape edge at the filler neck.  The tank doesn't have to leak to produce the problem you have.  Even fumes will eventually get under the raw paint edge.  I use JB weld to seal the edge.  Mask off an 1/8" over the paint edge, smear a small amount over the exposed raw edge, remove the masking, let it dry for 24 hrs. and that seals off any exposure to the paint.  It's a very simple and yet very effective fix to the problem.
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
Re: Paint Disaster
« Reply #51 on: August 27, 2014, 09:15:32 AM »
We must have been taught by the same guy back in the 60's when we had two choices....acrylic lacquer for trick painting and acrylic enamel for an automotive finish.  I used regular epoxy glue then.  The only difference I do now is after the epoxy seal is done at the lip and cured, I run a flex-hone in the filler neck and then immediately do my clear coats without sealing off the filler with tape.  The urethane creates a belt and suspenders type of seal over that edge.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
