Author Topic: 73 racer build  (Read 8620 times)
Offline Jhelgesen
    • Stahlwerks
Re: 73 racer build
« Reply #25 on: October 17, 2014, 04:13:33 PM »
The rear wheel was a bolt on with the 550 axle. Going to try fitting a disc brake wheel next, so we'll see if that fits.  I had to use the narrow sprocket carrier from a 750.  I'll need a new spacer on the right side if I don't use the disc brake.
Don't know about the front axle since I have the cbr front end. I did find a yamaha front axle that is the right diameter and may save me some machining.
Offline Lostboy Steve
Re: 73 racer build
« Reply #26 on: October 17, 2014, 06:34:27 PM »
That looks really sweet. So are you now going to have those adapters machined from aluminum?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Jhelgesen
    • Stahlwerks
Re: 73 racer build
« Reply #27 on: October 30, 2014, 07:07:26 AM »
Swapped the rear wheel to a 18"  750 sport disc brake wheel (instead of the 17" 750a drum brake wheel)  Lost 10mm in tire width, but I'll live. :D
Using a rear caliper from a 750 sport, and a GL1000 disc (same part number as 750).  I will need to narrow the caliper mount block to space the wheel correctly, take several mm off to center the wheel.
Front disc brake adapters arrived, fit perfect.  Need to make axle spacers now.  Found a yamaha front axle that was 15mm diameter, and longer than the CB, so I'll update my CAD for that one instead of making an axle from scratch.
Had to move the bike off the table for a bit while I work on another project, she has a pretty good stance.
Re: 73 racer build
« Reply #28 on: October 30, 2014, 05:14:14 PM »
The stance and the tank look good.
Offline Jhelgesen
    • Stahlwerks
Re: 73 racer build
« Reply #29 on: November 25, 2014, 09:32:09 AM »
Finished the front axle spacers after some slight tweaking on the lathe.
Now moving to the back.
Ended up fitting a 750 sport rear arm on the bike, perfect fit on the 550, bolted right on.  Only issue is the wheel is a few mm off to the left, need to figure out how to space back right.
A big thank you to my lovely wife who surprised me with with a new drilled EBC rear rotor for the bike, so much nicer than the stock disc.
Offline Jhelgesen
    • Stahlwerks
Re: 73 racer build
« Reply #30 on: December 28, 2014, 04:04:20 PM »
Wasn't happy with the raised front of the cx500 tank, so I formed some skirts to reshape the lower section, and installed the cap assembly.
Before
After
Offline Bankerdanny
  • Endeavor to persevere
Re: 73 racer build
« Reply #31 on: December 29, 2014, 02:13:15 PM »
So they are purely cosmetic skirts, they didn't actually change the volume of the tank?
Offline Jhelgesen
    • Stahlwerks
Re: 73 racer build
« Reply #32 on: December 29, 2014, 05:03:37 PM »
They are just cosmetic, but they greatly increase the space under the tank to hide wires, electronics, a tool kit, and maybe a few days worth of provisions.
Offline greenjeans
  • 1972 CB750K2
Re: 73 racer build
« Reply #33 on: December 29, 2014, 05:16:04 PM »
Really like what you did with that tank.  Great solution.  can't wait to see this one back on the road.
