Author Topic: J.Webster Designs Honda CB550 Project  (Read 5076 times)
Offline J.Webster Designs
  • www.JWebsterDesigns.com
« on: September 14, 2014, 07:42:04 PM »
Soooo, I was unsure if I was going to start a build thread on this bike or not... but here is goes.
The plan for this bike is some sort of Brat/tracker set up. Follow along to see where it ends up...
If you follow my Facebook (www.facebook.com/JWebsterDesigns) or my Instagram account (http://instagram.com/j.websterdesigns), then you have probably already seen a majority of these pictures. If you don't follow those accounts, check them out for more recent updates on what is going on at J.Webster Designs and what new parts we are coming out with.
Without further ado. Some pictures of what the CB550 looked like when I picked it up...
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
Instagram:
www.instagram.com/j.websterdesigns
Re: J.Webster Designs Honda CB550 Project
« Reply #1 on: September 14, 2014, 08:38:03 PM »
Current Progress on the CB550... The frame has been de-tabbed. All unnecessary tabs, latches, brackets were shaved off of the frame to clean everything up. I am a firm believer in "less is more" when it comes to motorcycles.
Most factory bikes are obviously built with ease of assembly in mind to cut down on the assembly costs at the factory. This tends to lead to things being placed in view, when a little more effort in tucking them away would make the bike more appealing to the eye.
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline cwchan
« Reply #2 on: September 15, 2014, 12:49:32 PM »
Any plans on making an adaptor for an oil pressure gauge on this one?
« Reply #3 on: September 15, 2014, 07:47:16 PM »
Yes sir!
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline brandEn
« Reply #4 on: September 15, 2014, 07:54:31 PM »
That tail section has a good shape and I like the color of the tank. Count me in on this build! Anytime a machinist build a bike I wanna watch
« Reply #5 on: September 15, 2014, 08:08:37 PM »
Especially one who adapts fuel injection to a CB
« Reply #6 on: September 16, 2014, 09:26:36 AM »
The CB550 did not come with a kick stand. No problem! Just make one!  I took a couple pieces of plate, tig welded them together, then milled it down to get some nice flat sides to it. Then glued on a leg to the bracket. I still need to cut it to it's final height, and make a foot and a spring attachment point. I will post pictures of the final product.
I am waiting to cut the leg to the correct height until I get the bike to full weight and the new shocks mounted so that the suspension sags to its final height.
What do you guys think?
« Last Edit: October 30, 2014, 06:21:51 PM by J.Webster Designs »
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline brandEn
« Reply #7 on: September 16, 2014, 09:31:53 AM »
beautiful weld!
« Reply #8 on: September 16, 2014, 09:57:46 AM »
Really great welding skills, JW.
« Reply #9 on: September 16, 2014, 10:15:25 AM »
Any plans for EFI on this bike?
« Reply #10 on: September 16, 2014, 10:26:25 AM »
Negative. This is just going to be a fun little bike. Plan is to have it rideable for the Barber Vintage Motorcycle Festival in October.
The CB550 is also no where near capable of supporting fuel injection on the electrical side...
However, I do plan on making some parts for the CB550s and using this bike to produce them. So stay tuned to see some of the new stuff.
VISIT OUR WEBSITE!
Facebook:
Instagram:
« Reply #11 on: September 16, 2014, 11:48:59 AM »
Will do.  I'm a fan of resto-mods.
« Reply #12 on: September 16, 2014, 07:35:25 PM »
I shaved and smoothed the lower triple to get rid of the original front brake sending unit location. Smoothing it out also got rid of the original rough cast surface and the poorly ground parting lines that came from the factory...
I also turned down the head of bolt and welded the bolt to the lower triple for mounting a pedestal mount headlamp. I like the look of pedestal mounted headlights, as it allows for clean look to the forks...
I need to weld shut that bolt hole in the triple that was used to mount the brake sending unit distribution block and smooth it over...
VISIT OUR WEBSITE!
Facebook:
Instagram:
« Reply #13 on: September 18, 2014, 05:25:20 AM »
The cylinders and head have been cleaned up and will be on their way to mreick for some refreshing...
Can't wait to get them back this is the first time that we have used Mike. Always see and hear great things about him.
Next up is to finish the electronics tray and finish mock up so that I can get everything out to powder and paint.
VISIT OUR WEBSITE!
Facebook:
Instagram:
« Reply #14 on: September 18, 2014, 11:18:41 AM »
You will happy with Mike's work.  As he says, "No disappointments no matter the displacement."
Offline r6100mph
« Reply #15 on: October 06, 2014, 07:08:04 PM »
What is that center scissor stand you are using?  I could definitely use something like that when I've got the front forks of the bike. Thanks
« Reply #16 on: October 06, 2014, 07:20:04 PM »
ive only ever known them as motorcycle frame jacks and motorcycle lift jacks.
VISIT OUR WEBSITE!
Facebook:
Instagram:
« Reply #17 on: October 30, 2014, 06:19:53 PM »
So I have been slacking at updating this build thread.. But the day to day is busy.
I have the battery box mocked up. I need to do some finish work on it, but overall its where I want it to be. I am waiting on word back from a new wiring dealer about new wire for the project as well as the cylinder and head to come back from Mike. I will be doing some testing on the Shorai battery on this build, so we will see where that goes.
Cheers!
VISIT OUR WEBSITE!
Facebook:
Instagram:
