Author Topic: Tube Size vs Tire Size  (Read 827 times)
Offline heyitsrama
« on: September 22, 2014, 06:01:06 PM »
Howdy,
Made an order from American MotorCycle Tire and they shipped me the wrong front tire tube. its been a few weeks since the order, but i had to get the wheels all sorted before i wanted to mount them on. anyway the issue that I have is that the Tube Size is smaller than the Tire Size. Tire is an 19, while the tube is a 17. However the tube fits well into the tire. see image below, and advise on what to do?
_____________________________________________________________________________
72' cb500
I can't believe it's not butter.
Re: Tube Size vs Tire Size
« Reply #1 on: September 22, 2014, 06:38:33 PM »
Simple, get the correct size tube.  Good choice on tire, love my Avons.
Offline heyitsrama
« Reply #2 on: September 22, 2014, 07:42:01 PM »
i tried used the search function.  8)
ill grab them tomorrow, pain in the ass installing your own tires?
72' cb500
« Reply #3 on: September 22, 2014, 07:57:07 PM »
Yes, unless you have a tire machine.  I pay a guy $20 to do it, worth every penny in my book.
Offline goldarrow
  • one day, i'll be an
« Reply #4 on: September 22, 2014, 08:16:51 PM »
Installing tire is easy.  Save $20 and spend on other parts
CB550 K0
Offline grcamna2
« Reply #5 on: September 22, 2014, 08:22:25 PM »
tire bead lube makes the job 100% easier  ;)
75' CB400F/'bunch o' parts'
Offline heyitsrama
« Reply #6 on: September 22, 2014, 09:32:10 PM »
i was told not to use the lube because it stays inside and can rust the wheel? baby powder was the alternative?
72' cb500
Offline grcamna2
« Reply #7 on: September 22, 2014, 09:37:04 PM »
That's true if it's only soapy water or some other caustic type liquid, but I use Murphy's tire bead lube which is good for the rubber and it's a paste so it won't run down onto your rim/spokes.
« Reply #8 on: September 22, 2014, 10:18:45 PM »
Have too many parts!
« Reply #9 on: September 23, 2014, 03:27:25 AM »
I use RU Glyde, works well.  The wheel rust - the exposure to water from rain is much bigger than one time only mounting, I certainly don't worry about that.
