Author Topic: Help. First start up after build. Oil pressure?  (Read 4581 times)
Offline cakey
  • 5% recipe and 95% process
Re: Help. First start up after build. Oil pressure?
« Reply #25 on: October 04, 2014, 07:41:10 PM »
Yes Mick I had partaken of much internal degrunging fluid since yesterday but I think it was something wrong with the mud crab 8)
So I fired it up. I couldn't see the oil ports properly once the bike was running but when checking the front tapped cover it went from a little bit of oil to filling up and out the hole pretty quick.
In the oil tank I could see a town of tiny bubbles coming up through the oil. Think I'm good to put this thing under load? It might be too loud for me today though.
1971 CB750 K1 (restored)
1975 GL1000 Goldwing (restored)
« Reply #26 on: October 04, 2014, 07:58:53 PM »
Yes ride it, yes you can adjust the floats with the carbs on. It's just harder to see when the little pin moves. I use the clear tube method to double check.
