Author Topic: Brake Bleeding Problem  (Read 1198 times)
Offline KC_Northstar
« on: December 11, 2014, 10:48:35 AM »
I Rebuilt the Master cylinder and caliper on my CB750 and never had any problem at all when it came time
to bleed them. I just got done rebuilding the MC and caliper on my wife's bike and cant get them to bleed.
I put fluid in the MS, opened the bleeder and I cant get any fluid to flow.  I loosened the brake line at the
MS and I don't even get one drop out there. I squeezed the brake lever and tied it down and left it about an hour.
No fluid going through at all.  Any ideas?
KC
KC
1971 CB750-K1
1972 CB750-K2
1971 SL350-K1
1971 SL125-K0
1979 CM400A
Offline goldarrow
  • one day, i'll be an
Re: Brake Bleeding Problem
« Reply #1 on: December 11, 2014, 11:18:24 AM »
Be sure the two tiny holes inside the reservoir are clean and clear
CB550 K0
« Reply #2 on: December 11, 2014, 11:49:59 AM »
I'm pretty sure they are.   The brakes were working before the rebuild.  With the MC being 30+ years old, I figured
I better rebuild it.  I cleaned it real good and ran a wire down both holes.  Before I remove it again, I just want to
see if there is anything to try first.  I figure that with the brake line loosened at the MC and the lever tied in place
at half way that it should at least drip out there. Could it be air locked somehow in the MC?
KC
1971 CB750-K1
1972 CB750-K2
1971 SL350-K1
1971 SL125-K0
1979 CM400A
Offline strynboen
« Reply #3 on: December 11, 2014, 12:06:48 PM »
tryn to" suck" the flouid aut at the caliber air nippel..somtimes if it are total dry,it blokes for flouid to come dovn in MC piston champer(bore)..
i hate all this v-w.... vords
« Reply #4 on: December 11, 2014, 12:46:37 PM »
OK, I took the MC off and mounted it in my bench vice.  I put my finger over the hose outlet.  When I push the lever I get pressure
on my finger and when releasing it vacuum, but no fluid.  So I figure one of the holes must be blocked.  So can I run a wire through
them again without taking it apart or would that possibly damage the rubber plungers??
KC
1971 CB750-K1
1972 CB750-K2
1971 SL350-K1
1971 SL125-K0
1979 CM400A
Offline goldarrow
« Reply #5 on: December 11, 2014, 12:55:08 PM »
Poke the holes with small wires be just fine
CB550 K0
Offline cabrala
  • Super Duper
« Reply #6 on: December 11, 2014, 01:54:03 PM »
Seems like you are heading down the right course of action. I had the same issue with my MC rebuild and found that bench bleeding the MC first was the difference. Once I got fluid pushing past my finger (blocking the outlet to the lines) I hooked everything back together and started the traditional bleeding process.
Best of luck once the holes are cleared.
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
Need a better, newer points cover gasket? How about rubber washers for the headlight bucket? Click the link below:
http://forums.sohc4.net/index.php?topic=122308.0
« Reply #7 on: December 11, 2014, 05:21:36 PM »
Ok, so I reinstalled the MC and still had the same problem.  I figured it was time to try a power bleeder.  I don't have a power
bleeder or speed bleeder, so I made one up.  I stuck the hose from my shop vac into a glass jar and the small hose I use for bleeding
in there too.  I sealed the hoses and the top of the jar with duct tape.  Instant power bleeder.   That did the trick.  I'm not real sure
those holes in the MC were really clogged.  I think if I had just power bled it from the start that it would have worked. In any case
the front brakes are done and I have a solution for power bleeding in the future.
KC
1971 CB750-K1
1972 CB750-K2
1971 SL350-K1
1971 SL125-K0
1979 CM400A
« Reply #8 on: December 11, 2014, 06:22:51 PM »
Good thinking.
My RD350 was impossible to bleed after a brake job, the power bleeder did the trick too for my too.
Offline mrfish2
  • I might be a
« Reply #9 on: December 11, 2014, 06:36:59 PM »
I was having trouble bleeding my new system as well. I ended up having to take it to a shop and let them bleed it with a vacuum system. Seems like this is generally the easiest and quickest way to go.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline Builder
« Reply #10 on: December 11, 2014, 07:33:53 PM »
A way I have found to bleed when the system is dry, is to pull the lever just a tiny bit until a bubble or series of bubbles comes from the small holes inside the master reservoir. I call it tickling. Just tickle away and it bleeds the air out, and the air gets replaced by fluid. If you start squeezing the lever right away, it doesn't bleed the air out as well. It can take a while, but it usually works to "tickle" it.
Offline DWS
  • Treat others as you would like to be treated .
« Reply #11 on: December 11, 2014, 08:21:38 PM »
might try this
Always looking for friends.
78CB750F3
PD 42A with original breadbox
4 into 1
valves adjusted to .003 (intake and exhaust) ( as was suggested for cooling )
slow jets#35 Main #110
 turned out to 1.5 some paper work says 1.75
4800 feet altitude
78 Honda CB 750 F3 Restoring now(Almost done)
BSA MX 50 Next
BSA b50T Parts
Offline krusty
« Reply #12 on: December 11, 2014, 08:45:25 PM »
+1. Works every time for me.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
