Author Topic: Carb butterflies nicked up  (Read 1273 times)
Offline fmctm1sw
« on: January 27, 2015, 10:49:33 AM »
I have an old 350 twin I'm working on.  In the process of taking the carbs apart to clean them, I had to removed the butterflies to get that shaft out of there and cleaned up.  To make a long story short, those butterflies were real soft and didn't come out easily.  In the process, I nicked up the bottom of one of them and had to dress it up a bit.
The bike idles high and I can't get it any lower.  Looking at the bottom of the butterfly, it looks like there's a gap now that I assume to be the problem.  I thought I might have them upside down but either way, the idle is near 2000 RPM.  Anyone have any thoughts...
« Last Edit: January 27, 2015, 10:53:55 AM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Carb butterflies nicked up
« Reply #1 on: February 02, 2015, 07:44:22 AM »
Kinda looks like it's not closing all the way?
Offline fmctm1sw
« Reply #2 on: February 02, 2015, 10:15:19 AM »
Exactly, I looked closely the other day and I had them in backwards.  The edges are angled slightly and I saw it after I looked real close.  I have to pull them again, it still idles a little high but I haven't adjusted the cables either yet.,..
Edit:  That little passage you see in the photo is now covered...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
