Author Topic: 1978 CB550 Rear Brake Light Sensor Spring  (Read 3089 times)
Offline pashracer
« on: February 01, 2015, 10:05:52 AM »
Can someone send some detailed pics on where the rear brake light spring attaches to? The rear brake light sensor is already installed on the bike but I don't think I have the correct spring and I cannot tell where the spring attaches to on the foot brake lever.
Also, does anyone know where I can purchase the correct spring? I ordered one online but it seems to be way too short to connect to anything!
Offline mrfish2
  • I might be a
Re: 1978 CB550 Rear Brake Light Sensor Spring
« Reply #1 on: February 01, 2015, 10:24:07 AM »
Here's how it's attached on my 76, pretty sure it's the same for a 78. Also, BikeBandit sells the springs brand new here (it's number 11 in the picture):
http://www.cmsnl.com/honda-cb550k-1978-usa_model7222/partslist/F++18.html#results
« Last Edit: February 01, 2015, 11:40:22 AM by mrfish2 »
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline pashracer
« Reply #2 on: February 01, 2015, 10:38:26 AM »
mrfish2, my brake lever does not have that hole mounted to it. I recently bought the bike used but it does not look like that tab with the hole was removed from the brake lever. Maybe the 76 and 78 are different?
Offline eigenvector
« Reply #3 on: February 01, 2015, 10:43:31 AM »
I've owned a fair number of motorcycles, they all pretty much look like that.  My '77 looks like that for certain.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline LesterPiglet
  • 1977 CB550F2
« Reply #4 on: February 01, 2015, 11:20:03 AM »
The brake pedals are NOT all the same. The F model spring attaches on the cam, inboard of the swinging arm.
http://www.cmsnl.com/honda-cb550f2-super-sport-550-four-1977-england_model17121/partslist/F18.html#results
« Last Edit: February 01, 2015, 11:23:00 AM by LesterPiglet »
Offline mrfish2
  • I might be a
« Reply #5 on: February 01, 2015, 11:39:30 AM »
He said his is a 78, and they quit making the F model in 77. They're still similar in the way the spring attaches, but a few of the parts are still different. I edited my first post to the correct parts diagram.
1980 CB650C - Sold
Offline pashracer
« Reply #6 on: February 01, 2015, 12:49:15 PM »
calj737, can you send a picture of how the spring mounts to the brake pedal cam? Also, do you know where to order the correct spring for the 1978 model?
Pash - here you go. The spring does mount differently on the '78. It attaches to the brake pedal cam
Edit: thanks Lester for attaching the link I meant to-
Offline DaveBarbier
« Reply #7 on: February 01, 2015, 03:15:22 PM »
I'm not at my bike now, but the '78 is different than the rest. I don't have a clear picture but maybe you can see in this.
There is a motor mount that also holds the clutch cable. The little bracket for the stop switch gets bolted with the motor mount. The spring then goes on the inside of the frame and hooks on to a notched "lever" that is shared with the brake rod that actually pulls the brake arm on the hub.
Hopefully this drawing helps. My handwriting sucks, sorry, haha.
1978 Honda CB550K
Offline DaveBarbier
« Reply #8 on: February 01, 2015, 03:19:55 PM »
This is it. Number 11 in the schematic.
Ebay link from Partzilla.
http://pages.ebay.com/link/?nav=item.view&alt=web&id=281476571034
Hope your bike is the same as my '78 CB550K
1978 Honda CB550K
  • 1977 CB550F2
« Reply #9 on: February 01, 2015, 03:29:00 PM »
But showed the wrong picture. I was showing the other brake arrangement, there only are two.
Offline pashracer
« Reply #10 on: February 01, 2015, 08:46:08 PM »
DaveBarbier, thank you for the image and drawing. Thats exactly what I needed!
Offline DaveBarbier
« Reply #11 on: February 01, 2015, 09:15:45 PM »
Glad I could help. If you need more pictures let me know. I'm back home and with the bike. Could take more shots in the morning.
1978 Honda CB550K
Offline happynen
« Reply #12 on: April 27, 2024, 12:39:47 PM »
Hi guys, I am at the same point now, but all the pictures you have shared here seem to not be available anymore. Do you think you could share once again? Just cannot get the way how to get it connected to that rocker arm.
Thank you!
Offline Little_Phil
« Reply #13 on: April 28, 2024, 09:41:21 AM »
Don't have a picture but this link is still relevant.
https://www.cmsnl.com/honda-cb550f2-super-sport-550-four-1977-england_model17121/partslist/F18.html#results
It connects to the cutout of part 12. so the spring passes behind the frame tubes to reach it.
