Author Topic: When compression ratings are out of whack  (Read 1044 times)
Offline eigenvector
« on: February 14, 2015, 09:42:56 PM »
I did my rebuild compression check today.  I'm not happy with it, but I have to fiddle with the valves some more.
Mind you I did my compression check via kickstarter - and honestly my kickstarting technique leaves much to be desired.
#1  100psi
#2  120psi
#3  145psi
#4  120psi
The number 1 compression rating in retrospect probably has to do with me giving up on it sooner than the rest.  It was the first one I did, and I didn't have a feel for when it was time to stop.  I'll fudge a bit and say it was in reality closer to 120psi  145psi seems a bit too high.  Mind you, the manual indicates that 170 psi is the 'standard' compression rating.
I'm trying to decide if I should dig into the #3 cylinder a bit or, since this is a fresh rebuild, get the bike running for a while - seat the rings and all that, and THEN start taking a hard look at the compression.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Re: When compression ratings are out of whack
« Reply #1 on: February 15, 2015, 01:54:10 AM »
+1 on getting it running first.
Why would you kickstart for compression check in the first place?
Offline chewbacca5000
  • I polish covers!
« Reply #2 on: February 15, 2015, 04:29:59 AM »
The best way I have found is to do your compression test with the carbs off and to turn kill switch on and hit the starter button for 5 seconds or so.  I would do that before "digging it" as your testing procedure is suspect.
Offline Bailgang
  • Scott
  • Indiana
« Reply #3 on: February 15, 2015, 04:40:02 AM »
Huh? Why would you want the coils energized when doing a comp test or is that a typo?
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
  • I polish covers!
« Reply #4 on: February 15, 2015, 05:57:45 AM »
Yeah typo.  Good catch.  Kill switch to off.
Offline eigenvector
« Reply #5 on: February 15, 2015, 07:50:59 AM »
Didn't have a battery handy at the time.
Kickstarter turns the engine over just the same.
In any case I'll just not worry about this for now.  It gets me a ballpark figure and I can live with that.  I'll revisit when I get a few hours on the engine.
Rob
1977 CB550K
1983 VF750S Sabre
  • I polish covers!
« Reply #6 on: February 15, 2015, 09:08:52 AM »
If you find comp is low then using 50/50 mixture of atf and acetone in 2 cylinders at a time helps to unstick rings which is a common problem if the bike has had a long sit.  Make sure pistons are all the way down then fill it up.  Let it sit for 2 to 3 weeks, and with plugs out kick it over.  Make sure no one or nothing is in your path it will shoot for 15' for more.  Repeat for other cylinder.  I did this and it brought the comp back up on all 4 cylinders.
Offline RevDoc
« Reply #7 on: February 15, 2015, 10:25:16 AM »
[/quote]
Hey, Chewie, thanks for sharing that great tip!
Dana
'78 CB550K--Angie
'82 CB750 Custom--Eva
As soon as you straddle a bike expect every other driver on the road to suddenly start competeing for the title "Dumbestsonofa#$%*inallNorthAmerica!!"
  • I polish covers!
« Reply #8 on: February 15, 2015, 04:24:08 PM »
[/quote]
Also, make sure you do it in warm weather no chemicals work less than 60F very well.  You can get alot done in 80F once a year here is Syracuse.
Make sure you, pets and others are clear when you kick it out.
Offline RevDoc
« Reply #9 on: February 15, 2015, 09:14:53 PM »
Having grown up in Auburn, 30 miles west of "Syracorpse", I know just what you mean, Chewie! ::)
Dana
'78 CB550K--Angie
Offline Hot500
« Reply #10 on: February 16, 2015, 01:18:13 PM »
If you have just finished a rebuild with new rings and honed or rebored sleeves, then the comp figures you have are fine.
Allow some time for the rings to bed in properly and you will see the comp figures come up towards the stated 170psi. ;)
CB500
SL350
KTM 990 Superduke
DR650 (sold)
DR250S (oldie but a goodie)
  • I polish covers!
« Reply #11 on: February 16, 2015, 03:47:16 PM »
It is a balmy 10f today!  Think I will head to the beach.  Where you at now?
Offline eigenvector
« Reply #12 on: February 16, 2015, 05:03:36 PM »
Thank you for the reassurance.
It's a bit irritating holding down a full time job and trying to rebuild an engine.  You have to wait 5 days in between to see if you're making progress.
Rob
1977 CB550K
1983 VF750S Sabre
