Author Topic: Early small grab handle fit 750 K3? 50316-300-030  (Read 857 times)
Offline Chachi
« on: March 19, 2015, 09:42:25 AM »
Will the early small grab handle fit a 750 K3? K3 has full wrap-around grab bar.
Part # 50316-300-030
Originally on K0-K2 (?)
https://www.davidsilverspares.com/CB750K1-FOUR-1970-1971-USA/part_168955/
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline greenjeans
  • 1972 CB750K2
Re: Early small grab handle fit 750 K3? 50316-300-030
« Reply #1 on: March 19, 2015, 02:01:18 PM »
Yes, I believe that it does.
Offline Chachi
« Reply #2 on: March 19, 2015, 02:55:07 PM »
If it doesn't, you'll cover the cost, right?!? (Insert appropriate emoticon).
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline Chachi
« Reply #3 on: March 20, 2015, 12:47:08 PM »
Anyone else able to chime in on this before I order one?
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
« Reply #4 on: March 20, 2015, 05:39:28 PM »
I think it will fit also.
Offline Chachi
« Reply #5 on: March 23, 2015, 09:17:10 AM »
Thanks. Just ordered one. The seller jtmarks77 (on eBay, but somehow related to the forum) said it would fit other K years in his description too:
-1969-1971 CB750 K0, K1
-Will also work on 72-76 CB750K if you don't have the full grab rail on
-If you are trying to get it to fit on other bikes the holes are 7 inches or 177.8mm center to center
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
« Reply #6 on: March 23, 2015, 10:46:48 AM »
It will fit, I think, but you'll have to remove the wraparound bar, which is also the turnsignal mount. The earlier signals mount a different way.
Offline greenjeans
  • 1972 CB750K2
« Reply #7 on: March 23, 2015, 11:07:50 AM »
Yes.   The early turnsignals mounted on the ends of the frame rails instead of the grab bar
Offline Chachi
« Reply #8 on: March 23, 2015, 12:37:49 PM »
OK. Thanks. I am swapping signals out too, so not a problem.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
