Author Topic: Fork Spring Loose?  (Read 918 times)
Offline Indy72
Fork Spring Loose?
« on: May 02, 2015, 01:17:58 PM »
I was out for a ride today (350F) and started hearing a clunk when I hit bumps. Then when coming to a stop while braking slightly I began hearing a rattle. I sounds to me like its coming from the springs in one of the tubes. I haven't had these apart before but does it make sense to anyone that these noises are coming from the spring or springs?
'72 CB350F
Re: Fork Spring Loose?
« Reply #1 on: May 02, 2015, 01:25:23 PM »
Before you tear anything apart check that the brake caliper isn't moving on it's bracket pin causing the clunk. Roll it back & forth and grab the brake to see if you can hear anything. It'll be worse on the street with more brake force applied.
Offline mgzych
  • '75 CB550F
Fork Spring Loose?
« Reply #2 on: May 03, 2015, 06:47:24 PM »
I think I have the clunk you've described on my '75 CB550F, bwaller. Is that possible?  How would I confirm and fix?
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #3 on: May 04, 2015, 07:49:05 AM »
If it was just when going over bumps, I would suggest it might be a cable slapping your headlight bucket (happens on mine)... but if also when braking, follow bwaller's advice.
--Evan
1975 CB750K "Rhonda"
Offline LesterPiglet
  • 1977 CB550F2
« Reply #4 on: May 04, 2015, 01:13:09 PM »
Check if the Allen screws under the axle are tight. When I first got my bike it was clunking. Jacked it up, took the wheel off and one of the fork bottoms detached. Screw unscrewed itself   ::)
