Author Topic: Gas Tank Rust Removal  (Read 10105 times)
Offline GizmoDuck
« on: May 27, 2015, 11:43:51 AM »
I have used EvapoRust for small parts before and love the stuff but not going to buy enough to fill my tank.  I have heard vinegar works, and shaking nails inside to loosen chunks of rust.  What do you recommend and do I leave the petcock on for it?
Re: Gas Tank Rust Removal
« Reply #1 on: May 27, 2015, 11:50:28 AM »
Do you have enough rust to need to rough it up/knock it loose with metal bits?
Might be able to skip that step.  you decide.
You can use what you have....just shake and rotate you tank a few times a day.
I filled my tank with golf balls to take up the volume...  plugged the fuel tap with a wine cork.
added 1 gal prepnetch.  filled the rest with water to top it off.  24 hours and it was like new inside.
Offline eshumaker
« Reply #2 on: May 27, 2015, 12:17:01 PM »
Subscribed!
1976 CB750 (basket case in progress)
1979 GL1000 Goldwing (runner)
1983 CB750 Nighthawk (basket case)
2004 Yamaha R6 (commuter)
Offline chewbacca5000
  • I polish covers!
« Reply #3 on: May 27, 2015, 12:26:37 PM »
Offline Lostboy Steve
« Reply #4 on: May 27, 2015, 01:01:10 PM »
Electrolytic rut removal.
First, fill tank with a good amount of lacquer thinner and bolts. Then shake the hell out of it. Once you get most of the rust and varnish out. Use the electrolytic method as described by me and many others on here.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline mrfish2
  • I might be a
« Reply #5 on: May 27, 2015, 02:00:35 PM »
I bought enough Phosphoric Acid from the local hardware (5 gallon container for like 10 bucks) store to fill my tank with, and 24 hours later it looked pretty good inside with all the rust gone. Rinsed it out with some baking soda/water mix to neutralize the acid, then rinsed with Acetone to get all the water out, and finally lined with Red Kote.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline dusterdude
« Reply #6 on: May 27, 2015, 02:50:23 PM »
The works,good stuff
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline dusterdude
« Reply #7 on: May 27, 2015, 05:43:57 PM »
Cal,cal,cal why are poo pooing on all the good suggestions here,especially mine.lol
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
« Reply #8 on: May 27, 2015, 05:51:28 PM »
He has not done as many as us---------------- Duck were you not selling that 350 cuz of a bad title ??
« Last Edit: May 27, 2015, 05:53:14 PM by ekpent »
Offline Imago
  • 1978 CB750F
« Reply #9 on: May 27, 2015, 07:04:26 PM »
...Rinse and treat promptly to avoid flash rusting.
What is recommended to use to "treat promptly" to avoid flash rusting? Is there a best practise?
Offline mcswny
« Reply #10 on: May 28, 2015, 01:35:25 PM »
Everyones got their own opinion and method. I used Prep n Etch, pretty cheap at HD, and filled the rest up with golfballs. Then neutralized with baking soda + water, the  water bath, then acetone and heat gun and compressed air. Worked great!
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Offline dusterdude
« Reply #11 on: May 28, 2015, 02:50:53 PM »
You're such a sweet fella cal,lol.btw,do we still have a date tomorrow?
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Justin
    • Cj's Garage
« Reply #12 on: May 28, 2015, 02:58:16 PM »
What about a tank that has some awful beige liner in it..? I think someone treated it long ago trying to coat over the rust or something but it's got a bunch of weird beige paint looking stuff inside. I don't care about the paint, there isn't any because I stripped it to bare metal to bang the dents out. I just want to know what will strip the inside liner out and possibly if there is any rust under neath the liner. Any suggestions?
Offline dusterdude
« Reply #13 on: May 28, 2015, 03:00:14 PM »
Groovy
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #14 on: May 28, 2015, 03:00:51 PM »
I like The Works method as well.
Sent from my Desire HD using Tapatalk 2
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
Offline jonda500
« Reply #15 on: May 28, 2015, 08:26:37 PM »
For safe removal of flakey rust I like to tip aquarium gravel into the tank, seal shut, thoroughly wrap in underfelt and tape, then stick it in the tumble dryer (cold setting) for as long as possible(at least a couple of hours), then blow out with compressed air and finally rinse out with diesel then petrol.
My tank has no loose particles just dark brown fuel residue varnish, I know seafoam would dissolve this but I am in Australia where seafoam is not available (unless you wanna pay $59.99 per bottle!!). Would acetone be a suitable alternative? (I will be repainting the outside!)
A starter clutch thread:
Offline Justin
    • Cj's Garage
« Reply #16 on: May 28, 2015, 09:46:31 PM »
Want me to post you some of the magic elixir called SeaFoam? I think the customs lads would confiscate it if they opened the box, but that SeaFoam stuff is excellent. and only about $8 USD a bottle in the local hardware shop.
Offline Justin
    • Cj's Garage
« Reply #17 on: May 28, 2015, 09:47:35 PM »
Justin - An acetone soak will remove an existing liner. Use 2-3 gallons. An overnight soak will erode the liner, then drain, and treat bare metal for flash rusting.
cheers, Cal. I'll do just that and report back as to how it went  :D
Offline mcswny
« Reply #18 on: May 29, 2015, 07:09:07 AM »
Yes it will! Only downside to this method, as I mentioned, is the risk to paint damage. I'm not advocating one method over another as "better", purely indicating risks associated with each  :)
Yeah, the paint on my bike isnt good anyways. It was powedercoated black at one point 20 years ago and is super beat up so definitely going with the "patina" look so I dont mind a little more. :)
1972 CB750 K2
1975 XL250
198 XR80
Offline jaguar
« Reply #19 on: May 29, 2015, 07:27:59 AM »
I use "The Works" toilet bowl cleaner.
Great stuff and cheap.
Offline harisuluv
« Reply #20 on: May 29, 2015, 10:22:18 AM »
I am currently using vinegar in my rz350 tank which is pretty pristine outside but inside rusty and even had multiple pinholes.  Using vinegar cause as calj mentioned it's safest
Offline Big Red
« Reply #21 on: May 29, 2015, 05:54:19 PM »
Good Evening,
I used white vinegar and let it sit for a couple of days. It worked like a charm.
Getting all of the rust and goo once clean takes some shakes with more vinegar and water.
For the time and effort, I would do it again.
G
1978 CB750 Brat
Offline heyitsrama
« Reply #22 on: May 29, 2015, 11:39:27 PM »
When i was working on mine what i ended up doing was using an electrode with some washing soda inside the tank to remove a good amount of it out. Followed with compressed air to dry out all the water inside. After that I used Evapo-Rust and did rotations to the tank inside a container with a pan on the bottom of it to collect it from any leaks. To get it all over the inside of the tank I would walk over and rotate it to its side. You can use a ziplock baggie to seal up the gas cap to get a full rotation, which will stop the leaking somewhat. But just have a pan on the bottom to collect that Evapo-Gold. Stuff is expensive.  ;)
_____________________________________________________________________________
72' cb500
I can't believe it's not butter.
Offline GizmoDuck
« Reply #23 on: May 30, 2015, 12:02:35 PM »
Went with Vinegar.  For $8 if it doesn't work then I can always try something else.
Offline AlekStooge
  • can't afford cheap stuff
« Reply #24 on: May 30, 2015, 12:56:37 PM »
It's a drag getting rocks, nuts and bolts out... never again.
I used metal rescue and that worked very well, downside is its $100 for 5 gallons. I think I'm going to try the viniger or toilet bowl cleaner method next time.
