Author Topic: 500 to 650 CAM swap - Tolerance between lobes and case?  (Read 1249 times)
Offline Puffin
Whilst rebuilding my CB500 engine I took the opportunity to swap the stock CAM for a 650 CAM.
Although all the lobes clear the engine case the tolerance by the #4 cylinder is very small however I can't make it physically touch by manually manipulating the cam and it spins freely.
At the time I left it but going back and looking at the pictures I'm not so sure?  That is one small gap..!
I've buttoned it all up now but if I need to go back and grind away some of the case then so be it.
I assume there is not a recommended set distance between the lobes and the case?  Is there likely to be any lateral movement of the CAM as the engine is running?
Any thoughts would be welcome.
Honda CB500 four
Honda CB350 four (under construction)
1972 Cb500 Rebuild Project - http://forums.sohc4.net/index.php/topic,145835.0.html
Offline Scott S
Re: 500 to 650 CAM swap - Tolerance between lobes and case?
« Reply #1 on: May 31, 2015, 05:36:32 PM »
 I clearance that with a Dremel tool.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline faux fiddy
  • bike in a box
« Reply #2 on: May 31, 2015, 11:38:07 PM »
Not a bad idea. Grind some away, that's what it's there for.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
« Reply #3 on: June 01, 2015, 07:54:11 AM »
It's a good idea to get some clearance Clarence.
Offline Dunk
« Reply #4 on: June 01, 2015, 12:07:24 PM »
Definitely clearance it, with heat and speed things can grow and move a bit.
Offline Puffin
« Reply #5 on: June 01, 2015, 09:31:12 PM »
Balls....!  You are all correct of course.
I'm kicking myself because I was meaning to clearance test the new CAM in the head before I installed.... but I totally forgot.
Guess I'll be undoing a few things tonight..  Gonna be fun doing it with the engine on the bike but I have one of those flexible dremel extensions somewhere.
Honda CB500 four
