Author Topic: cb550 dual outlet fuel tap compatibility discovery  (Read 1086 times)
Offline jonda500
« on: June 01, 2015, 09:30:41 PM »
After finally getting lucky and picking up a genuine 1975 cb550F supersport fuel tap for my 12/74 cb550F I discovered to my dismay that it's a larger diameter than the threads on the 77/78 cb550FourK tank that I bought. (Yes I should have measured before buying it!) I surmise that the fuel outlet is a smaller diameter on the later model tanks. Also the filler flap is different having a bracket spotwelded on the underside that prevents the flap from closing unless the fuel cap is done up. (The older models fuel cap's hinged handle is replaced with a traditional ridge on later model caps.) As this will still end up looking like the right tank for my supersport project I decided I will still use it.
So I went out and rummaged around in my garden shed and pulled the fuel tap off what looks to be an early cb250 tank that I found at the tip. It has twin outlets and a sediment bowl and low and behold it fits my 550K tank perfectly!
Now my only concern is whether it might be too long and hit the engine! -I will update when I find out.
« Last Edit: June 01, 2015, 10:39:17 PM by jonda500 »
A starter clutch thread:
Offline turboed13b
Re: cb550 dual outlet fuel tap compatibility discovery
« Reply #1 on: June 01, 2015, 09:43:11 PM »
77 550f have single outlet petcocks the older f models had the dual outlets which leaked because of the design.
I also have a 74 f model I think mine is #11
Offline jonda500
« Reply #2 on: June 03, 2015, 11:23:44 PM »
Well it looks like it will work- I think this fuel tap may be the same on early cb250/350/450/500T models so not rare like the '75 supersport one!
Offline jonda500
« Reply #3 on: June 03, 2015, 11:27:35 PM »
Number eleven! -and I thought I had an early one! (#1064)
