Author Topic: Whats Your Favorite Tank Liner???  (Read 6051 times)
Re: Whats Your Favorite Tank Liner???
« Reply #25 on: June 04, 2015, 07:18:01 AM »
 I haven't lined one yet but I owned one with a liner in it. No trouble ever. I'm going to use Caswell on the fiberglass tank on my nostalgia drag bike. Just in case alcohol accidentally gets in there. I'm told it's the only one listed for fiberglass.
Offline jonda500
« Reply #26 on: June 04, 2015, 07:23:51 AM »
Here's my 500 tank - a mate pulled the dents out with an ezybeat which left me with lots of little holes & tears
I gently banged the holes in slightly with a slag hammer and braized them up with the oxy welder, then ground & filed off the excess brass. After checking thoroughly for leaks it was ready for the paint shop...
Looks great now with its $800 paint job & has been in use for over a year without any liner/tank sealer products used and is still 100% leak free!
edit- The shop would definately have used some bog(bondo) under the paint to even out the surface.
« Last Edit: June 04, 2015, 07:40:14 AM by jonda500 »
A starter clutch thread:
Offline AlekStooge
  • can't afford cheap stuff
« Reply #27 on: June 04, 2015, 09:53:12 PM »
Time to pick your head up and learn some things, Alek. Your opinion of Bondo and tank liners are similar; low due to reputation. I'm not saying that people don't "misuse" Bondo to hide mashed in tanks, or body panels, because they certainly do. And honestly, not all people have the tools or trade to remove small dings and dents from surfaces, making Bondo a necessity.
Here's a tank I repaired. Despite all my efforts, some amount of Bondo was required (about a fingernail's worth). Crease was pushed out as well as I could, then metal was filed, then sanded, and still you can clearly see the divot. No other option than to add some surfacing mud (Bondo).
When you use Bondo would you have problems polishing/powder coating? Like when using liner?
Same principles for tanks. Here's one I repaired for a buddy. Discovered a huge amount of Bondo concealing a bashed in front edge (hidden below a rattle can paint job). Guy had a very limited budget, and needed transportation. Despite working the metal, it was so fatigued, that even after patch and welding, there were leaks. Liner required (and some filler). Looks perfect now, and holds fuel. Another tank saved!
Offline rtbmrgl
  • Got Points! Roseville, Ca
« Reply #28 on: June 04, 2015, 10:14:28 PM »
+1 Caswell.  Have 2 tanks with it.
+2 caswell, just lined my K6, should have done it a year ago. A year ago I brazed holes, fixed dents, and painted my 750 tank. I couldn't find any leaks after repairs, used the air pressure soapy water method. One year later a small bubble appeared in the paint, will seal next time I have a tank that had holes repaired. Luckily the bubble was under a decal.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
« Reply #29 on: June 05, 2015, 04:42:40 AM »
The bottom line is: Bondo is a tool like any other
Its nothing like Fenders Cal...!!   8)
Offline jonda500
« Reply #30 on: June 05, 2015, 07:05:06 AM »
N.B. I have had three personal encounters with tank liners- all three were bad ones - but all three were the kreem variety, first time was when one failed in my rz250 - but maybe the PO didn't do it properly; second failure was when I stupidly added valve saver to my custom one piece frame/tank 500 race bike(sadly it killed that project for me!); third encounter was helping a friend try and line his harley tank- this is not a large tank but when we got to the final step (adding the cream to the tank) we found it quite impossible to get it to spread thin enough to coat much more than half of the inside. He later purchased another bottle of kreem but reportedly still didn't quite achieve full coverage an that stuf ain't cheap - he was NOT happy!
-however maybe the kreem, which was purchased from two different stores here in Australia, was old stock.
Caswell sounds like good stuff - if I ever have a rust pitted tank to repair I'd like to try it. :)
Offline petecb400
« Reply #31 on: June 05, 2015, 11:39:02 AM »
No liner.  Add 365 in your tank.
Offline grcamna2
« Reply #32 on: June 05, 2015, 12:01:30 PM »
I had a Vintage Norton fiberglass tank lined inside;someone recommended a boat place.I super-clean the orig. surface inside and then I took it to the boat guy who did a 'Gel coat' clear fiberglass on the inside and let it set-up for a while before use.The tank has been in use for a while now and holding up well even w/ the E-gas we've been having to use.
75' CB400F/'bunch o' parts'
Offline grcamna2
« Reply #33 on: June 05, 2015, 12:06:35 PM »
Nice job on saving the bad tank(w/ the left dent/rot) in your lower pics Cal.  8)
Offline Eddie
« Reply #34 on: June 05, 2015, 03:22:26 PM »
I have a 75 GL1000 that the tank is fairly clean but after I de-rusted it, it developed pin holes in the seam. I'm going to try KBS Coatings gas tank seal. they have a 3 part system. Cleaner, Rust blast then the sealer. Good reviews. If you could find a new tank they are $600+...no way.
Offline grcamna2
« Reply #35 on: June 05, 2015, 06:20:42 PM »
Those GL1000 tanks are deep into the rear of the frame(they're like a auto style tank!)and I think it's a B*tch to get'em out.I like that they're hidden from direct sunlight so they don't have the same problems(heat-cool-heat-cool>condensate..)that our upper tanks do.
« Reply #36 on: June 05, 2015, 06:52:33 PM »
I did that for SulphurDave in New Orleans. HE was pretty happy to get it back in one piece, sealed, and primed. He was very tight on his budget, but wanted to get his bike running very badly. A few hours of work, and a couple of days in the mail.
You can check out the whole process of pictures in his thread (it was a wreck!)
Cal is a "Tank Whisperer"!  He also did a fine job on one of my 550 tanks, still owe ya big time, Cal. Thanks again.
Offline cakey
  • 5% recipe and 95% process
« Reply #37 on: June 06, 2015, 03:34:01 AM »
I used POR 15 in both my GL1000 and CB750 K1 tanks and they both still look like new inside a couple of years later. I havnt faulted the product yet.
I spoke to the rep from POR 15 and he advised me on the final coat to put duck tape over the fuel filler hole and then poke my air compressor gun through the tape and give a squirt of air. The pressurising in the tank forced the POR 15 into the seams and any places it would normally flow over the top of. Good advice I thought at the time and I did it.
1971 CB750 K1 (restored)
1975 GL1000 Goldwing (restored)
Offline chewbacca5000
  • I polish covers!
« Reply #38 on: June 06, 2015, 06:01:32 AM »
So yesterday I went to home depot to get Xylene to make up some homemade rubber renue and noticed that they have the real MEK back in stock!  You know the nasty stuff.  For those who need to remove a stubborn tank liner this will do it.
No idea if your local Home Depot has it, but mine does.  Yippee!
Offline rtbmrgl
« Reply #39 on: June 06, 2015, 07:25:58 AM »
Just read the Kleen Strip website info on MEK, "Not intended for sale or use in California."
Well it should say not for sale in calif.
My drug, gun runner smuggler can get it to Calif.  What the heck, are we motorcyclist or a gang of bikers,
lets get organized and corner the market on MEK in Calif. Ill setup the Sacramento area.  ::)
thanks, Mark
Roseville, Ca
Got Points!
  • I polish covers!
« Reply #40 on: June 06, 2015, 08:25:13 AM »
MEK is the only way to get good results with RedKote which is MEK based.  You can think RedKote with Mek to get really good even coverage.  I had a small can was hanging on for emergency.  Now I might do this tank on my bike.  We'll see.  Getting sick of all the burbs and farts it is giving me due to junk in tank.
Keeps saying "Where is my gas"?
Offline LesterPiglet
  • 1977 CB550F2
« Reply #41 on: June 06, 2015, 12:35:57 PM »
I have never met anyone who used any type of liner. What's it's purpose? If your tank has holes, it is due to rust and the rust will still spread using a liner. Fix it properly by brazing or gas welding.
  • 1977 CB550F2
« Reply #42 on: June 06, 2015, 01:03:08 PM »
If rusted through then the rust is also on the outside and will still spread. I'd rather do it right and repaint.
« Reply #43 on: June 06, 2015, 01:53:58 PM »
Not necessarily true, my RD tank has rust only on the inside. I treated it and coated with Caswell.
There was no way I was repainting this 40 year old survivor..
Offline AlekStooge
« Reply #44 on: June 06, 2015, 02:01:49 PM »
Use liner only when you want maintain original paint? Otherwise weld and line afterwards if you want to help prevent rust? Am I correct? I personally don't care if the paint is original (I'm not like everybody). Most original paint has rust or fading, so it needs to be redone anyway.
« Reply #45 on: June 07, 2015, 05:34:13 AM »
Not unusual for people to still get a peek a boo paint bubble eventually appear after a tank repair. Good liner is just one more layer of protection.
Offline grcamna2
« Reply #46 on: June 07, 2015, 04:11:42 PM »
That is a Very nice 73' RD350A fuel tank Stev-o   8) How's the bike running ?!
« Reply #47 on: June 07, 2015, 09:00:31 PM »
Thanks, the bike runs great. However, the clutch slips above 6K, I have the parts, need to rebuild the clutch.
Offline xtravbx
« Reply #48 on: June 08, 2015, 06:33:45 AM »
I use red kote. Covers well. Flexible so it doesn't get brittle and crack apart (which ive seen happen with caswell).
Also Kreem is crap. I'm working on a customer's tank now that has a Kreem bladder pulling away inside it.
« Reply #49 on: June 08, 2015, 08:21:00 AM »
 Thanks for the info on liners, I'm looking at doing one myself. There is a place for these products, an original paint tank has more value then they used to and are worth saving.
