Author Topic: Dual Disc Fitment Question  (Read 655 times)
Offline kseries
« on: June 06, 2015, 08:45:22 AM »
Hey All,
I am currently working on a dual disc conversion for a 77' CB550.  I plan on doing without the speedometer.  I fitted the rotors without the speedometer gearbox retainer and gearbox retainer cover using only the gearbox as a spacer in its original position.  Everything seems to line up and rotate appropriately, but I wanted to make sure this would work without any fail.  TIA
Offline DaveBarbier
Re: Dual Disc Fitment Question
« Reply #1 on: June 06, 2015, 11:04:39 AM »
I'm in the beginning stages of a dual disc conversion too but I haven't started assembly so I can't help you. But Godffrey sells spacers to use if you remove the speedo. Might be a good idea to get.
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/Parts+and+service/Speedometer+Blanks/
1978 Honda CB550K
Offline kseries
« Reply #2 on: June 09, 2015, 12:12:06 AM »
Definitely makes for a cleaner look! Thanks
