Author Topic: cb750 chopper  (Read 3960 times)
Offline 1stgenxxx
cb750 chopper
« on: August 16, 2015, 12:25:46 PM »
well....I bought this solid cb750 yesterday! I'm going to make a few changes (bars, rear fender, seat, forks) This thing rips!
Offline Desert-SOHC
  • It's old
Re: cb750 chopper
« Reply #1 on: August 16, 2015, 12:52:06 PM »
Nice find!
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Re: cb750 chopper
« Reply #2 on: August 16, 2015, 12:58:36 PM »
Groovy!   Congrats...
Offline SOHC Digger
  • I'm not an
Re: cb750 chopper
« Reply #3 on: August 16, 2015, 03:28:04 PM »
Nice solid bike! A few finishing touches and it will be tight!
Offline 1stgenxxx
Re: cb750 chopper
« Reply #4 on: August 16, 2015, 04:16:04 PM »
same thing I said when I saw it!
Offline 1stgenxxx
Re: cb750 chopper
« Reply #5 on: August 25, 2015, 07:52:53 AM »
I got the bike home sunday night and got to ride it yesterday. The carbs will need a good cleaning.....It had short overflow tubes that were plugged. The bike flooded and I barely got it fire back up roll starting it down a steep hill.
The engine is a K0!
Seems to be a very early chop in an AAE frame....Hailcraft 15" rear wheel with a 750 front rotor/caliper on the rear.
Re: cb750 chopper
« Reply #6 on: August 25, 2015, 09:30:02 AM »
Nice I would. Turn the rear fender around, think it's backwards .
The front end might be KO,what is the engine Number?
 I think  that dragbars with built-in risers would look pretty good.  I made a set by welding a flat plate to bottom of the bars. The plate was drilled to fit the stock tree. IIRC I had bent the ends over to hide the halfmoon cutout in the trees.
Offline 1stgenxxx
Re: cb750 chopper
« Reply #7 on: August 25, 2015, 09:47:31 AM »
After looking a little more....I think the engine might be sandcast. 1004xxx I think. that would be a pretty solid buy for 1400$
Re: cb750 chopper
« Reply #8 on: August 25, 2015, 11:11:54 AM »
Okay look at the number pad on engine, it should not have a raised frame around it
 The lower legs look KO from what I see.. But they probably. Are worn if it has many miles.
With the right pipes, you can lower the front a lot..
On the discs, the aluminum center part, is the edge square or tapered down  to almost point?
Re: cb750 chopper
« Reply #9 on: August 25, 2015, 11:52:42 AM »
This is what Frank means about the rotor hub:
Offline 1stgenxxx
Re: cb750 chopper
« Reply #10 on: August 25, 2015, 12:17:51 PM »
The tubes are extended and right side is a little rust under the dust boot.
I will take a look at the rotors tonight
Offline 1stgenxxx
Re: cb750 chopper
« Reply #11 on: August 25, 2015, 02:05:06 PM »
I was wrong :( it's a K-0. Last digits of vin are 37xxx.
Still glad to have an early motor
Re: cb750 chopper
« Reply #12 on: August 25, 2015, 02:26:44 PM »
Well, how did you come up with the 4xxx number?  Your forks look like KO. It's the radius below the wider seal area that is different.
So check the rotors.
Looking at the head is there a bolthead in the middle between #2 and#3 plugs.
 Carbsare are not KO
Offline 1stgenxxx
Re: cb750 chopper
« Reply #13 on: August 25, 2015, 06:10:20 PM »
 Carbsare are not KO
I had just glanced at the vin....and thought it was in the 4000s
engine number is 1037366 so that should make it a k-0
The front rotor is the tapered one and rear has the raised edge.
Offline 1stgenxxx
Re: cb750 chopper
« Reply #14 on: August 27, 2015, 06:20:45 AM »
I took the bike for a ride on Monday and it almost left me stranded. The po had plugged the overflows so I made it about a mile from the house and gas started pouring out of my pods. The bike flooded so i cut the gas off and was able to get roll started and made it back to the house.
Pulled the carbs and they were super clean but aparently need new needle/seats.
I also took the hacked up front fender off and started brainstorming on a new seat/fender
I will be relacing the rear hub to a highshouldered AL 19" rim.
The front will also be highshouldered on either a stock hub or spool.
Offline 1stgenxxx
Re: cb750 chopper
« Reply #15 on: August 27, 2015, 06:48:34 AM »
I'm going to unbolt the fender and rotate it forward to get me by for a month or so
The fork brackes are coming off when I get it to the shop
Re: cb750 chopper
« Reply #16 on: August 27, 2015, 08:03:05 PM »
19" rear rim?
Re: cb750 chopper
« Reply #17 on: August 27, 2015, 10:54:09 PM »
That's a new one on me, too.
Offline 1stgenxxx
Re: cb750 chopper
« Reply #18 on: August 28, 2015, 06:20:41 AM »
19" rear rim?
I'm considering it....
Ive already got a 19" hoop. I'm going with a 21 on the front.
Re: cb750 chopper
« Reply #19 on: August 28, 2015, 06:24:37 AM »
Most guys usually dropped the rear of their Choppa....
Offline 1stgenxxx
Re: cb750 chopper
« Reply #20 on: August 28, 2015, 07:28:15 AM »
Yea most of them do.....but I'm a fan of a bigger rear wheel. Drawing inspiration from a lot of shovels that Ive seen with 18" rear wheels. I may end up buying an 18" hoop if I can find one at a decent price
