Author Topic: quick welding question / stainless / non-stainless  (Read 1416 times)
Offline greenjeans
  • 1972 CB750K2
« on: October 15, 2015, 08:05:30 AM »
Can you tack steel to stainless steel ?
Building a coffin gravity racer and I have a piece of stainless tubing that I'd like to run a steel bolt through and then tack it so it stays put.
What happens when you try to weld stainless to regular steel ?     I'm using a Hobart 220 mig with shielding gas.
Offline Mantree
Re: quick welding question / stainless / non-stainless
« Reply #1 on: October 15, 2015, 08:16:24 AM »
Yes if you use stainless filler rod you should be fine but tig would be better
Sent from my SM-G900V using Tapatalk
Offline greenjeans
  • 1972 CB750K2
« Reply #2 on: October 15, 2015, 08:49:53 AM »
I guess i should add, that the welding wire I have in the machine is for normal steel.
Normally, I'd just try it and see what happens, but the parts are painted and if it doesn't/will not work, I'd rather leave things alone so I don'e have to patch up the paint work.
Offline strynboen
« Reply #3 on: October 15, 2015, 12:56:25 PM »
i have weldet stainless and soft steel together vith a standart vire in my co2 velder..no problem
i hate all this v-w.... vords
Offline faux fiddy
  • bike in a box
« Reply #4 on: October 15, 2015, 11:05:01 PM »
A friend patched a hole in my muffler with a piece of thin stainless and I think he used regular wire.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline Bootsey
« Reply #5 on: October 16, 2015, 02:08:34 AM »
Anyone think it would it be possible to patch an exhaust with some stainless sheet, using an Arc/stick welder and small  stainless rods?
Or would it more than likely to blow holes even with 1.6mm or 2 mm electrodes?
« Reply #6 on: October 16, 2015, 02:32:39 AM »
Yep, you can MIG stainless to mild, or mild to stainless using plain wire, no problemo. Same/same for stainless wire. Cheers, Terry. ;D
« Reply #7 on: October 16, 2015, 02:35:07 AM »
Arc welding is really better suited for welding thicker material mate, but you can probably weld anything if you're patient enough. Cheers, Terry. ;D
« Reply #8 on: October 16, 2015, 03:49:42 AM »
I will just throw it in here, there is a gassless SS wire for MIG now:
I am sure welding under gas is better, but it is good to have an option.
Offline faux fiddy
  • bike in a box
« Reply #9 on: October 16, 2015, 09:21:23 PM »
I would use inert gas, and avoid being near a fan.  I bet it can be done, though.
