Author Topic: "Mile High" CB350 Four project  (Read 38724 times)
Offline Denver_Larry
Re: "Mile High" CB350 Four project
« Reply #175 on: August 23, 2017, 07:15:29 PM »
Only problem I'm seeing with that is that I'll lose travel with every mm I add with the spacer... ugh
2005 RC51
1973 CB350F...project
Offline jag767
« Reply #176 on: August 23, 2017, 07:55:22 PM »
Ironically if you had gone with Hagons it'd fit fine lol.
« Reply #177 on: August 23, 2017, 08:11:52 PM »
So if I take 6mm out of the clevis, I'll still have 4mm of thickness to thread into.  Seems like that should be enough?
2005 RC51
« Reply #178 on: August 23, 2017, 10:43:09 PM »
Reverse the clevis so the offset is on the chain side. That should move the spring outward.
There is no offset to the clevis from what I can tell.
2005 RC51
Offline innovativems
    • Innovative MotoSports
« Reply #179 on: August 24, 2017, 05:15:06 AM »
Had a brainstorm:  if I run the preload collars up the shocks, I could have spacers made for the bottom spring perches that would get the perch moved straight up about 15mm and I think that would do it.
Ate those race tech shocks? I wouldn't want to shim the spring up
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #180 on: August 24, 2017, 07:15:40 AM »
No, Fox.  Thought a lot about the shim last night and yeah it's a bad idea.  Most likely going to machine the clevis.
2005 RC51
« Reply #181 on: August 24, 2017, 08:45:28 AM »
I thought those looked like Fox shocks.  Are they an off the shelf model or did you have them specifically built for this bike?
« Reply #182 on: August 24, 2017, 08:54:29 AM »
Off the shelf models, I can't remember the length I used off the top of my head though.
2005 RC51
« Reply #183 on: August 24, 2017, 10:01:59 AM »
Reach out to Devin. They have an offset clevis version to address this issue.
The Answer Man delivers again!
« Reply #184 on: August 24, 2017, 10:25:38 AM »
Reached out last night, waiting to hear back specifics on how it mounts and if it adds any length.  I don't want to change my geometry at this point in the game.
2005 RC51
« Reply #185 on: August 24, 2017, 12:33:17 PM »
Hopefully it just offsets the mount to provide clearance.
« Reply #186 on: August 24, 2017, 12:36:40 PM »
Exactly. The clevis is offset to move shock body outboard. No change elsewhere.
That sounds like the ticket!
« Reply #187 on: August 24, 2017, 01:34:06 PM »
This is what Devin sent for pictures.  It looks like I need a different config for the shock, and I'm not sure how the pivot mounts to the swingarm.  Really hoping it's not a welding situation...
2005 RC51
« Reply #188 on: August 24, 2017, 02:11:09 PM »
Just heard back from Devin.  I was looking at the picture wrong!  It wasn't the mount that changed, it was the spring perch that changed.  He had the same idea of raising the perch, but it looks like he's done it in a way that lets the perch/spacer will overlap the shock body to a certain degree and retain the travel.
2005 RC51
« Reply #189 on: August 31, 2017, 05:00:00 PM »
Need some opinions!  Front fender arrived from Cliff and I'm debating on placement.
Slightly forward:
50/50:
Slightly back:
I've got my feelings, but I want to hear from the "mob"!
2005 RC51
« Reply #190 on: August 31, 2017, 06:56:49 PM »
50/50 looks balanced.
Offline jag767
« Reply #191 on: September 01, 2017, 02:05:15 AM »
Forward
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #192 on: September 02, 2017, 05:40:08 PM »
I like slightly back as well.  That way your painter can tell which end is which.   :)
« Reply #193 on: September 02, 2017, 05:51:32 PM »
I'll draw an arrow for you on the underside
2005 RC51
« Reply #194 on: September 02, 2017, 07:42:21 PM »
When I pulled my (front end) back on my SuperHawk just 1/2" behind straight-up, every time I rode in the wet it zeroed in with the splash dead-center of my nose(!) Hated that...
« Reply #195 on: September 06, 2017, 07:24:22 PM »
This will be the front fender's final resting place, thanks for the input gang!
2005 RC51
« Reply #196 on: September 09, 2017, 03:58:14 PM »
First stab at fabbing some fender stays, happy with the result!  Now to cook up the 2nd set.  Slow but steady!
2005 RC51
« Reply #197 on: September 10, 2017, 07:34:19 AM »
Haha, had a torch out and everything!  The editing department would bankrupt the show since I'm so effin slow..
2005 RC51
Offline 75hondacb400
« Reply #198 on: September 10, 2017, 11:34:39 AM »
What type of jig did you use to bend those bars? I have attempted it a couple of time with no success
Offline nvr2old
« Reply #199 on: September 10, 2017, 11:56:11 AM »
All one has to do is to go back to the opening page of this thread to see how much work has gone into this bike.  An amazing transformation that I eagerly look forward to progress on.  This bike is going to be a blast to ride.
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
