Author Topic: O-rings for "3-way" Connector on Keihin Carb  (Read 1348 times)
Offline gdgreen56
« on: December 13, 2015, 02:04:52 PM »
I'm rebuilding the carbs on my '76 K6 and am trying to find the correct replacement o-rings for the "3-way' fuel connectors. The carbs are original to the bike (stamped 086A - ANH) . The "A" after the dash is enclosed in a square box.
There are two of these fuel connectors, 1 between carbs 1 and 2 and 1 between 3 and 4. There are 2 grooves on each side of the connector. The grooves in the "3-way" have a square cross section so I'm wondering if a square cross section ring is required? The diameter at the bottom of the groove measures 8mm and the width is about 2.5mm.
Here is a pic of the connector with one of the rings removed.
I'd appreciate any input on locating replacements.
1976 CB750K Cafe Project
2007 VT1100C2 - Sabre
Offline CycleRanger
  • No comment about being an
Re: O-rings for "3-way" Connector on Keihin Carb
« Reply #1 on: December 15, 2015, 09:17:52 PM »
They are included in the carb gasket set.
PN:16010-300-305
« Reply #2 on: December 15, 2015, 11:50:33 PM »
Hack a week just posted up his carb rebuild video and mentioned the size o-ring he used.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
--Evan
1975 CB750K "Rhonda"
Offline gdgreen56
« Reply #4 on: December 18, 2015, 07:01:46 AM »
Thanks guys! Very much appreciated.
BTW, here is a recent pic of the project I'm working on.
Offline cb750k7
  • My CB AKA Charlie Brown...(K8 frame with K6 engine
Found real friends here !!!
Offline CycleRanger
« Reply #6 on: June 09, 2016, 10:49:02 AM »
PN:16010-300-305
http://www.boats.net/parts/detail/honda/H-91301-MJ0-003.html
Nice!
Once you know the size (7.8x1.9) you can get them anywhere.
« Reply #7 on: June 09, 2016, 12:28:16 PM »
Offline Jonesy
  • Shop Rat
« Reply #8 on: June 09, 2016, 12:34:35 PM »
Someone on eBay was selling a set of 8 just for the fuel tees.
I just bought the carb kits listed above for the same reason. I should have them soon...
Offline bochnak
    • How-To Motorcycle Repair Blog
« Reply #9 on: June 09, 2016, 01:26:04 PM »
Check out Apple oring calculator. I sometimes go through this and order a pack of 50 for a few bucks:
http://www.applerubber.com/oring-gland-calculator/
I've seen OEM's charge 3-4 per oring. Markup is nuts!
Offline KCbarsos
« Reply #10 on: June 09, 2016, 09:46:28 PM »
I believe the great HondaMan said somewhere that 2x8mm o-rings work. I just ordered some from http://www.oringmonkey.com/advanced_search_result.php?keywords=2x8mm&x=14&y=10 They are en rout as we speak.
Offline cb750k7
Offline Deltarider
« Reply #12 on: June 10, 2016, 08:24:30 AM »
Although my bike is a CB500, I'd like to share my experience. On the CB500 you'll find a similar T-joint with two O-rings on either side. Maybe my bike is an exception, but on mine the O-rings still seal well after 40 years. Last year I had to replace the fuellines and those of you that have done this chore, know what a struggle it is to get the fuellines over the nipples of the T-joints. I had lost my temper and was really using violence to get them on. I was almost sure I had damaged the O-rings on T-joints in the process and that it (finally) would be my turn to replace them. With little hope I opened the petcock. Guess what, nothing leaked, nothing. You should have seen how wild I had moved the T-joints back-and-forth. Unbelievable. Honda did well by putting two O-rings on either side. So you may consider just to keep what you've got. You can simply test if they still seal and leave them where they are.
« Last Edit: June 10, 2016, 08:28:11 AM by Deltarider »
CB500K2-ED Excel black
