Author Topic: Wolfey's 1976 CB550 Street/Track Build  (Read 10704 times)
Offline Wolfey
« on: January 26, 2016, 02:52:19 PM »
Hey everyone. I figured its time to create a thread on my build. I bought this bike a year and a half ago July 2014 not running. They previous owner threw the chain and blew out the neutral switch assembly and didnt know how to repair it. Well I got it home, grounded the neutral switch to the case and jumped it with a battery charger. 15 minutes later I had a running CB550K in decent condition. Here is a few picks of that day.
Well I rode it in this condition for the rest of the summer before my Friend Mel Chiro and I decided to tear it down and build a street/track 550 that is a hybrid of old and modern.
First came the tear down.
Getting the engine out was and absolute pain!!! I ended up laying the bike on the side and having to lift the frame off upside down to get it out.
Next the engine went to the shop for a big bore (603cc) and decked the head .006". While that was being done we decided that we where going to detab the frame and put a few braces in.
One of the things we noticed while taking apart the bike is that one of the previous owners had dumped it on the right side and blew out the whole side of the case. Instead of replacing it they welded it all back together and welded the case together in the process.
We had to cut the case with a grinder to get it open.
The new case looked to be in good condition. It looked like they maybe had siezed a bearing and threw a connecting rod.
More to come later tonight..... with pics.
« Last Edit: January 27, 2016, 03:14:19 PM by Wolfey »
Offline Wolfey
Re: Wolfey's CB550 Street/Track Build
« Reply #1 on: January 26, 2016, 03:44:59 PM »
Yep thats how I tried to do it, but it was having clearance issues. Probably removing the pan would have helped. The end solution was to have it on its side and stand the bike upside down off the motor.  :D 8)
« Reply #2 on: January 26, 2016, 08:40:00 PM »
Interested to see where you go with this.
Welding a case together?! What the heck was the PO thinking!?  :o
Offline Wolfey
« Reply #3 on: January 27, 2016, 03:13:27 PM »
Next I wanted to update the front end so I found a 2004 GSXR1000 front end for a good price. I also wanted to add better tires and rims for racing so I went with the jixxer wheel up front and a SV650 rim in the back to accomodate the 160/17 tire I wanted.
Unfortunately the rim didn't fit and align correctly in the stock swing arm. We did figure out that we could flip the swing arm and get the alignment to work.
Basically this is where I am now on the bike. I have a rolling frame and now slowly been collecting parts lately for a big push to get the bike more together.
Couple other images....
Did some custom plates for rear sets.
Think I am going with this for rear lights. Just need to build a bracket to mount it. Been waiting to get my custom seat so I have that for placement.
How the front end will look.
My instrument guage I am using.
Bike with the new rear shocks on it. Need to finish the mounts though.
This week I received the Seat and a new 5 3/4" Headlight bucket with shock tower side mount brackets. More pics this weekend when I get a chance to start mocking them up to mount and build brackets.
Re: Wolfey's 1976 CB550 Street/Track Build
« Reply #4 on: January 27, 2016, 03:36:27 PM »
I don't get how flipping the arm aligned the wheel, it could just be the pics but the wheel now looks offset to the right....?  The chain line is out with the swingarm in the normal position, the easiest way to fix that is to machine down the sprocket carrier... Is that a 4.5 x 17 inch rear rim..?
Offline Wolfey
« Reply #5 on: January 27, 2016, 03:56:15 PM »
It is a 4.5/17 rim. The way the rim sat in the swing arm right side up it was offset to the frame. Flipping the swing arm with the SV650 rim aligned it to the frame.
Probably could have had the sprocket carrier machined down but this fixed it without any machining needed.
« Reply #6 on: January 27, 2016, 04:00:46 PM »
Race it?...what sanctioning body has a class for such modifications?
Offline Wolfey
« Reply #7 on: January 27, 2016, 04:23:37 PM »
No racing, just track days. I have a group of friends that appreciate air cooled bikes. they build and track them during the summer in the Pacific Northwest. Most of them do the DOHC 750s, 1100s, and CBXs. I love the SOHCs and found this 550 and thought it would be the perfect bike to build.
« Reply #8 on: January 27, 2016, 04:34:12 PM »
Interesting, machining the carrier is a hell of a lot less work that what you've done, you mean the spacers didn't line the wheel up ?, they are easy to fix too..?  You'll will still have problems with chain line if that wheel is centered, the Suzuki carrier sits out a lot further than the honda one, even a 10mm offset front sprocket isn't enough to line the chain up properly.... I have already done a 4.5 inch Suzuki rim into a Honda swingarm, it was relatively easy...
« Last Edit: January 27, 2016, 04:41:00 PM by Retro Rocket »
« Reply #9 on: January 27, 2016, 04:34:32 PM »
Cretins Seattle?
Offline Wolfey
« Reply #10 on: January 27, 2016, 04:43:39 PM »
Interesting. Right now we are just doing mock up/build up. We were kinda waiting to get the engine back and get that back together to figure out the front sprocket. With the swing arm right side up there was no spacer on one side and all on the other plus because I went with a 160/17 (if I would have done a 140/17 I wouldnt have had any of these problems, I like a challenge though  :D ) tire there was rubbing issues. By flipping the swing arm, we got spacers on both sides, the tire to line up to the frame and the tire to not rub on the swing arm.
Possibly when we get the engine in the frame it sounds like from you we will still have to machining the carrier to get our chain to line up properly. Even if this has to be done there wont be rubbing issues like there would have been with the stock swing arm right side up.
« Last Edit: January 27, 2016, 04:49:18 PM by Wolfey »
Offline Wolfey
« Reply #11 on: January 27, 2016, 04:50:31 PM »
Cretins Seattle?
No. Some nice looking bikes they have though.
« Reply #12 on: January 27, 2016, 04:51:43 PM »
sounds very fun...wish their were similar heads in my neck of the woods
« Reply #13 on: January 27, 2016, 04:58:28 PM »
I still can't work out the rubbing issues..?  That pic i posted is a 180 slick on a 4.5 inch rim, no rubbing when centered correctly, It is a 750 arm but they bolt straight into the 500/550 anyway, others here have fitted rims like that without the problems you say you are experiencing..  Look for Rustyolives 550, he has a 5.5 inch rear rim in a stock arm if my memory serves right... ;)
EDIT, looks like RO made a new swingarm to run the 18x5.5 inch rear rim. I'll post the thread for you anyway... ;)
Rusty's bike...
Rusty's build thread...
http://forums.sohc4.net/index.php/topic,81683.0.html
Offline Wolfey
« Reply #14 on: January 27, 2016, 05:08:10 PM »
Rusty's bike...
That's a nice bike. I will have to read that post tonight  :) If I would have went with a 750 arm I wouldn't have had issues. I had two choices: To try and make the stock arm work or make one. We figured trying to make it work would be fun to try. I will take closer pics this weekend when I play with the bike unless my friend posts some.
Offline Wolfey
« Reply #15 on: January 31, 2016, 08:23:36 PM »
Worked on the bike some more today. Got the whole front end mounted and put where I want it.
Also worked on getting the rear light and the seat mounted. With the seat I picked I needed to cut part of the rear off. It worked out really well because I was able to mount a bracket to hold the light perfectly under the seat.
Loving the seat. I think the brown is going to look awesome with a fresh new coat of that green on the tank.
« Reply #16 on: January 31, 2016, 09:43:31 PM »
Do you realize that the guard mount you removed from the rear of that bike actually stabilizes the rear suspension by removing flex...?
I'd be reinforcing that somehow...
Offline Wolfey
« Reply #17 on: February 01, 2016, 06:17:16 AM »
Tying the ends together should have solved that mostly, Retro. With no passenger seating/weight, the forward flange does most of the bonding of the seat rails, and his flat stock tied across should see him do alright. I just hope he replaces the stock P.O.S shocks to support the front end changes.  :)
I am actually going to reweld the cross brace back on in some fashion for mounting to the seat too. So there will be more cross stability also.
Hahaha yes I have new shocks :) I just put the old ones on because I didnt want to cut/weld around the new ones!
« Reply #18 on: February 01, 2016, 07:53:49 AM »
With the Suzuki triple tree branding, you got yourself a Honduki.
What shocks are you planning to use?
Offline Wolfey
« Reply #19 on: February 01, 2016, 09:32:35 AM »
I do want to replace that badge with one of the Honda wing ones.  :D
I am using 340mm RFY air shocks with 485lb spring rate. Here is a pic of them mocked up.
« Reply #20 on: February 01, 2016, 10:38:42 AM »
I might be reading your post wrong, but are your shocks set up for a 485lb bike? If so, it will be over-sprung.  The stock 550 weighs 423 wet, and you've shaved some of that weight.  You may also want to check your fork springs when the build is complete, as the change in weight may warrant different springs.
Your speedo/tach instrument looks similar to a Koso, but I didn't see the model on their website.  Where did you source it?
Offline Wolfey
« Reply #21 on: February 01, 2016, 10:59:16 AM »
I will have to check on the shocks. They only have one rating on the springs. I havent personally tested them. They are much stiffer but I can get give out of them. I am leaning to they might just have them overrated and be rating them as a set, not individually. I did find this review of them. http://chrislivengood.net/wp/rfy-340mm-shock-analysis/ They state 140lbs per spring which seems much more realistic. The earlier information I just grabbed from the information the seller put on them. (They were an ebay purchase  :) ) ( They might have been posting the max spring rate too at full compression which would make sense on these since they are a variable rate spring.)
It is a Koso gauge. RX2N GP Style http://kosonorthamerica.com/product/rx-2n/ Its the BA015B15 Model.
« Last Edit: February 01, 2016, 11:55:57 AM by Wolfey »
Offline Wolfey
« Reply #22 on: February 07, 2016, 05:06:04 PM »
Started working on my head porting it. I read the FAQ from Hondaman about creating the pocket above the intake valve, but I couldn't find anything more specific. So I found a few pics of other members on here and went to work. I think it turned out pretty nice! Only 3 more intakes some exhaust work to go....
Before photo:
The pocket area.
Before:
Offline Blackfin5
« Reply #23 on: February 07, 2016, 08:44:57 PM »
Wolfey...you've really have me fascinated with this project.   Are you planning to stiffen the frame at all?
Offline sbeckman7
  • Glutton For Punishment And/Or
  • Slow and steady
« Reply #24 on: February 07, 2016, 10:06:34 PM »
This is getting good :)  What exactly are you doing with those intake "pockets"?  Hard to tell from the pics.
Spence
