Author Topic: Newer Honda cb650  (Read 838 times)
Offline davifigo
Newer Honda cb650
« on: April 21, 2016, 02:43:53 AM »
Hi people!!
I pick my new/old bike...really well maintained..but seat in the last 2 years..
I have change the oil and the filter..but runs with that sound as in the video..
Never try on the road..
I think from the sound come to the right crankcase...maybe it could be the transmission chain?
Any info will be appreciated..
Inviato dal mio SM-G928F utilizzando Tapatalk
Offline strynboen
Re: Newer Honda cb650
« Reply #1 on: April 21, 2016, 05:47:56 AM »
cam chain.
.get it adjusted..and then vaccum cyncro...and hope it take it..if not the clutch basket dampers can be vorn..so it run metal to metal and the plastic /rubber elemens are gone.
..but get that chain adjusted first..and thek for oil in the valve areia..a burned cam shaft..can make that,,but often it just the chain rattel hard
i hate all this v-w.... vords
Offline davifigo
« Reply #2 on: April 21, 2016, 08:34:34 AM »
Hope not all this things...
Bike was regular used and than stored..
Offline cb650
« Reply #3 on: April 21, 2016, 12:52:25 PM »
If the top end has ever been apart make sure the cam chain adjuster is in properly.
A few threads on it here and on the 650 site.
Offline davifigo
« Reply #4 on: June 23, 2016, 08:00:08 AM »
After a month I just picked up my bike and spin around the country...
Bike runs well,I had change tires, liquid, fitter, Oil , brake pads..etc BUT still not convince too much...in fifth gear if I release the throttle and than accelerate again, nothing happens for half second..and then go fine..every time I tried do the same...any issue?
« Reply #5 on: June 23, 2016, 08:14:30 AM »
Please complete a valve adjustment, cam chain adjustment, check/adjust timing, advance.
Finish this service with a vacuum sync of the carbs.
If you have these tools, it should take you not much more than an hour.
