Author Topic: can i do a compression test with no oil in engine and oil pan off? 81 cb650  (Read 8680 times)
Offline basketcase81
that is all
Offline CB650CPastor
Other guys may have different opinions on this but I wouldn't spin an engine without oil in it.
Tim
Current:1980 Honda CB650C Custom, 1969 Toyota Corona Deluxe Sedan
Past: '07 Honda Rebel 250, '80 Yamaha XS1100 Special, '69 Honda CB160, '67 K15 Suzuki Hillbilly, 1971 VW Super Beetle...
Offline Bodi
Not a problem for a compression test.
Offline strynboen
a komp test is not giving a lot of info..if your engine ..not is be running dayly or atleast for 2 or  more auers..before a test...a dry aut and oil free engine vill give a strange low resultat. valvets vill not seat real good..
..so if it is a barn find..or a non runner...get it running and give it a shake Down before try/vaste any time on that
just running a old dry engine vill give better resultats..so get it running and do the test..and see if all cylenders give the same resultat..
« Last Edit: May 01, 2016, 12:46:32 PM by strynboen »
i hate all this v-w.... vords
Yes you can. I done it for my 750.
I figured it would be ok, but i didnt like the idea. Im losing my patience with this thing so I did it anyway.  ;)
I got 80 on #1, 90 on #2, and ~110 on #3&4
This bike was sitting for an unknown amount of time and I am in the process of rebuilding. PO didnt put the cam tensioner in correctly and bent all the valves. I got a good used head and these are the numbers i got. Should I keep going or should I look for something else causing those low numbers?
Thanks
I did. see my reply to Pastor if you can help with that. Thanks
« Last Edit: May 21, 2016, 11:05:34 AM by basketcase81 »
Offline Flyin900
Did you test the valves in the used head with a liquid leak test for sealing before installing the head?
Like Strynboen said an engine that has sat for a long time the rings aren't going to seal well and the valves may be suspect in your new head if you didn't test or lap first.
I would get it running as suggested and see where your at after a hundred miles of riding. Soaking the cylinders with ATF and acetone mixture will help free stuck rings and clean out carbon.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
i did not test the head. I have since got this thing running for a couple seconds with starter fluid (couldnt hook up the gas tank). Now trying to run fuel lines but vacuum pump is missing from carbs
Offline Bankerdanny
  • Endeavor to persevere
You put the oil pan on an added oil before you ram or I hope.
Offline Airborne 82nd
oil pan oil gas who needs all that extra stuff ;D Throw a little sand in there well it might already be there. jk
Offline Gene
  • Chat enuf you too can be a
Im losing my patients with this thing so I did it anyway.  ;)
You will need patience with an old bike.  Not trying to be a d&*k, but that's one tool you will absolutely need.
*1973 CB750K3 (Bow)
of course
yep, slowed myself down. feeling better now
