Author Topic: CB500/550 Keihin carb rebuild guide - 627B, 022A, 087A  (Read 3297 times)
Offline Bootsey
« on: May 25, 2016, 08:24:32 PM »
I stumbled across this recently, not sure if it's already here on the forums somewhere, but if not, I thought it might be of use to some folks.
It's a rebuild/disassembly guide for the Keihin 087A carbs - but I believe the info & steps would also be relevant to the 627B's and 022A's - if that's not so, please correct me.
It has good photos and seems to be a pretty decent guide, that could also be used alongside the Honda manuals. Resident carb guru harisuluv gets a no doubt much deserved mention!
I've attached the file or it can be found here: http://blacksquaremotorcycle.com/wp-content/uploads/2015/02/HOW-TO-REBUILD-KEIHIN-CARBTORS.pdf
Offline Bootsey
Re: CB500/550 Keihin carb rebuild guide - 627B, 022A, 087A
« Reply #1 on: May 25, 2016, 08:25:04 PM »
Whilst on the topic, there's another good guide here: http://www.motorcycleclassics.com/mc-how-to/honda-cb500-carburetor-rebuild.aspx
Offline Deltarider
« Reply #2 on: May 25, 2016, 11:54:57 PM »
Ofcourse I can't judge the necessity of your labour from here, so forgive me I give a warning in general: after having used a similar set of carbs for over 135.000 kms and 36 years I still cannot think of one reason why I would undertake all this. For maintenance and/or cleaning removing the floatchambers is enough. All relevant parts can be serviced from there as I've described more than once. I do not recommend to separate the carbs from each other. Minute (black) parts are easily lost in the process and I doubt you'll ever find replacements.
« Last Edit: May 26, 2016, 03:13:17 AM by Deltarider »
CB500K2-ED Excel black
Offline mrfish2
  • I might be a
« Reply #3 on: May 26, 2016, 05:00:34 AM »
Not every carb rack has been continuously used for 36 years Delta. The ones that have sat for 36 years will be the ones that require complete disassembly to clean and inspect every part. Maybe for you cleaning the float chambers is enough, but not for the racks that have been sitting.
Nice find Bootsey, it'll help a few people. Maybe get this added to the rest of the files on here somehow.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #4 on: May 26, 2016, 05:22:22 AM »
A great addition to the library thanks Bootsey.  ;)
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #5 on: May 26, 2016, 01:44:55 PM »
Ever heard of a barn find? You're definitely in the minority of people that bought bikes brand new and kept them and maintained them for 35+ years. Every bike I've ever bought used needed a carb rebuild.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #6 on: May 26, 2016, 01:47:29 PM »
this one qualify?
Offline Deltarider
« Reply #7 on: May 26, 2016, 02:09:02 PM »
That's why I have choosen my words as I did and if my warning does not apply to you... good. But... I wouldn't like people that are new to carbs to think this is the 'when you do it, do it good' approach, because in most cases it is outright overkill and it can have unnecessary frustation as a consequence..
Offline Bootsey
« Reply #8 on: May 26, 2016, 06:42:09 PM »
I'll agree with you Delta, I'm all for not making more work for yourself when it's not necessary, which is why I decided not to strip my carbs to this degree - but obviously that isn't always the case in every situation. This post wasn't made to convince anyone that they should do so, but merely to share some information that might help fill in some of the gaps in the shop manuals should that work need be done.
