Author Topic: 550 K0 rescue  (Read 6367 times)
Offline MoMo
  • Ride like you're invisible
Re: Just brought home a K0 550
« Reply #25 on: May 31, 2016, 05:39:54 PM »
^^ neither have I, what are rubber bands used for?...Larry
Offline MoMo
« Reply #26 on: May 31, 2016, 05:45:24 PM »
On a 500/550/650 valve cover, since the rockers are integrated into the cover, rubber bands are stretched from intake to exhaust tappet to hold them all "up" as the cover is installed; reducing the chance of bending a valve or such ineptitude. Can be done without using them, but its like wearing a helmet when you ride- Chances of survival are better.
Always wear a helmet, guess I'll have to start wearing rubbers....................................................bands that is...Larry
Offline jonda500
« Reply #27 on: May 31, 2016, 05:47:34 PM »
the rubber bands are used to hold the rockers up so they can't hang down and get caught on the edge of the valve stems when slapping the cover back on (can bend valves when you tighten it down) - I check them with my fingers and eyes and have never seen it happen...
John
A starter clutch thread:
Offline MoMo
« Reply #28 on: May 31, 2016, 05:50:12 PM »
John
I constantly check every rocker when reassembling a 500/550-never had a problem so I don't need no stinkin' rubbers
« Reply #29 on: May 31, 2016, 08:57:36 PM »
OK....remember the rubbers whenever the head cover goes on. Got it.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #30 on: May 31, 2016, 09:59:20 PM »
The school nurse told me the rubber was to cover the head, did I miss something?
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #31 on: June 02, 2016, 02:04:33 PM »
I have never used rubber bands in my life to replace a cylinder cover? - if you're blind & fingerless or have no mechanical aptitude, please do use them!
John
Thanks for being a today's jackass, I appreciate it. The last guy to mown and work on my first 550 didn't use rubber bands it cost me several new valves and guides. But I like that UR 'special'.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Re: 550 K0 rescue
« Reply #32 on: June 02, 2016, 06:01:40 PM »
Valves were waaaaaaaaay out.  Like measured in mm out :o
Cam chain adjusted
Daiichi points plate removed.
Advancer all rusted up, so a short detour to clean, polish, and trim springs.
Lubed and installed back on bike with a TEC plate and points.  Static timed.
Offline grcamna2
Re: 550 K0 rescue
« Reply #33 on: June 02, 2016, 06:17:45 PM »
Nice 550 flybox  8)
75' CB400F/'bunch o' parts'
Re: 550 K0 rescue
« Reply #34 on: June 04, 2016, 06:56:32 AM »
Piston and cyl wall
Odo shows 20k+....someone did some work in here. :D
Offline Lostboy Steve
Re: 550 K0 rescue
« Reply #35 on: June 04, 2016, 07:16:41 AM »
Piston and cyl wall
Strange that it looks fresh inside but the points plate and stuff was in need of attention. Nice find either way!
www.lostboysatomicgarage.com
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Re: 550 K0 rescue
« Reply #36 on: June 04, 2016, 08:53:43 AM »
That's a good thing, hopefully  :-\
Key word: hopefully.   At only 20+K miles, it would make me curious why it needed work?
Hey Fly - what boroscope is that? Link??  The quality looks real good, I'd like to pick one up.
Re: 550 K0 rescue
« Reply #37 on: June 04, 2016, 12:40:44 PM »
Here is the thread about it  ;D
http://forums.sohc4.net/index.php/topic,155785.0.html
Re: 550 K0 rescue
« Reply #38 on: June 06, 2016, 07:56:51 AM »
Finally getting it light enough to get up on the gurney to deal with the snapped pan bolt.
Going to try left handed drill bits first.
Someone thought more wax was better ::)  Plastic putty knife cut through the majority of this.
ZEP Purple and a pressure washer did the rest.
Offline tweakin
  • tear down
Re: 550 K0 rescue
« Reply #39 on: June 06, 2016, 04:35:18 PM »
Thats a score, good luck with bringing it back!
Re: 550 K0 rescue
« Reply #40 on: June 09, 2016, 04:54:09 PM »
The offender.  Snapped oil pan bolt.
No match for my Implements of Extraction
Offline CycleRanger
  • No comment about being an
Re: 550 K0 rescue
« Reply #41 on: June 09, 2016, 06:57:30 PM »
Well done! My efforts are almost never as successful... :\
Offline Cityscapedview
Re: 550 K0 rescue
« Reply #42 on: June 09, 2016, 08:48:22 PM »
Great find!
1971 Honda CB 500
David
Offline grcamna2
Re: 550 K0 rescue
« Reply #43 on: June 09, 2016, 08:51:28 PM »
Great find!
Good work removing that broken oil pan bolt.
Re: 550 K0 rescue
« Reply #44 on: June 14, 2016, 08:51:33 PM »
Would a few hard smacks with a BFH and some heat and a good penetrating oil be a better first start than breaking out the drill? Heck I would be doing that and use a good set of vice grips on it before drilling it.
