Author Topic: 78 CB 550K motor rebuild  (Read 65978 times)
Offline DaveBarbier
Re: 78 CB 550K motor rebuild
« Reply #325 on: July 22, 2017, 03:12:31 PM »
The actual clutch material will wear much more than the plate. The plate is checked for flatness. You don't want it warped. Glass is usually flat enough to test with as long as it's fairly thick. Thin glass can bend a tiny bit.
Offline AlekStooge
  • can't afford cheap stuff
« Reply #326 on: July 22, 2017, 06:03:10 PM »
Ok I see.
Offline DaveBarbier
« Reply #327 on: November 08, 2017, 05:14:07 AM »
Hey Alek, any update?
Offline skinsfn36
« Reply #328 on: November 09, 2017, 08:31:46 AM »
This was a good read through.
I'll be going through something similar in the coming weeks.
Did you ever compile that list of rings and seals?
Offline AlekStooge
« Reply #329 on: April 10, 2018, 03:11:23 PM »
I've been gone a long time. I haven't done anything to the bike over the past winter. I became a pilot so that became my focus.
I think I am just about ready to carry the engine to the garage, just a few more things to do.
I set valve lash to running clearance .004 intake and .005 exhaust (I believe it's correct I still doubt my self, I set it so there is little drag, I figure better a little loose than too tight).
I got the C5 set up. My problem was I didn't have a good ground through the backing plate. I thought the MAP wires ground the ignition. I just ran a ground wire from a bolt in the picture above. It lights up no problem now, always learn the hard way never easy. >:(
Clutch is installed. I only replaced the springs as I mentioned in the post above. I had trouble torqueing it down and cracked a couple bolts around 60 inch lbs? Not sure why manual says 7.1 lbs to about 10 lbs. I ended getting 25mm length bolts with washers and just tightened it down snug.
I got the other right cover on and I wasn't going to put in the starter just make it a kick only. I was concerned oil might come through the opening, not sure that's true. I'm sure people take the starter out when racing to reduce weight so I think not.
Now, couple questions. With my new electronic ignition I read people scribe a new timing mark for TDC 1/4 should I do that? Please walk me through it. My degree wheel is still on.
How do I rotate the crank from now on? Alternator side? What about this old points nut?
I will be moving on to cleaning the carbs again, putting the oil pan/filter housing on, installing the intake manifold, moving the engine upstairs and laying electric out.
Offline DaveBarbier
« Reply #330 on: May 22, 2018, 04:49:15 AM »
Hey Alek, get answers to any of hear questions? I just scrolled down in my feed farther down than normal and see you’re back at the rebuild.
Plug the starter hole if you’re removing the starter. You can buy plugs made for this purpose.
Unsure you still have the degree wheel on but if you do, set the engine to TDC 1/4 and then scribe a line on the case and on the alternator rotor. That’s your new TDC mark. I suppose there’s a risk of the rotor slipping and spinning on the crank end and making your marks off, but these rotors are pretty tight on there.
What’s your status on the motor now?
Offline AlekStooge
« Reply #331 on: September 18, 2018, 09:48:42 AM »
Dave, didn't see that. I already removed the degree wheel. I can make a scribe some other time. I guess for now I can use my light from my ignition as a point of refrence I think. I'll check out those plugs for the starter, anyone got a source? I came back here to ask about my fuel petcock. With my set up will I need a larger one for more fuel flow or will my carb changes alone be sufficent enough to take care of that?
Offline AlekStooge
« Reply #332 on: September 18, 2018, 10:46:01 AM »
Thanks Cal, I'll just replace the stock one with a fresh new one in the future.
Offline tanner709
« Reply #333 on: September 18, 2018, 07:14:45 PM »
Great work  Alek, I just read through the entire thread. You've gained a lot of valuable knowledge since the beginning. Keep the updates coming!
Offline AlekStooge
« Reply #334 on: September 19, 2018, 02:39:26 PM »
Thank you, I agree I went down the rabbit hole for my first engine but I learned so much.
I ordered a lot of parts. I am waiting for some more to come in, so I am looking for things to do in the mean time. I put fresh jets in 105 on the mains and 45 pilot. I have a rebuild kit so I used some parts like the float gaskets but I will replace most of the brass after I get my carbs ultrasonically cleaned in the Spring. Yes I cleaned them with carb clean several times.
I learned a cool trick to get the pilot jets to seat snug. Remember these are pressed in on the PD46C carbs. I took the old pilot jet and placed the orifice side to the orifice on the new one and gently but firmly hit it with the butt of a screwdriver. Otherwise they wouldn't stay in for #$%*. Brass is soft, so I used brass on brass and neither jet had any damage.
I took the chain cover off and replaced the sprocket. I remembered there was a O ring on the primary shaft behind the seal that I forgot to put in. I think I'll be fine though. The starter is just in there for now, I don't plan on hooking it up. I hooked up the neutral and oil pressure switch. Those are supposed to go to + correct?
Offline AlekStooge
« Reply #335 on: September 19, 2018, 03:24:23 PM »
...and 45 pilot. :o That's a large pilot for PD46s. Why did you go up so high?
Denny Zander's guide, stock is 42, 45 is the next size up.
Put the O-ring in. Its there for a reason from the factory.  ;)
I would have to split the cases again. It is part 40.
https://www.cmsnl.com/honda-cb550k-1978-usa_model7222/partslist/E++15.html#.W6LKeO_QZjo
Negative. They go to Negative.  8)
And please do something about those crappy blue plastic connectors. Those will fail promptly. Weather shielding is highly encouraged for those connections.
No way how so? :o I thought ground was -. Yes I will most certainly do something about those plastic connectors. I have a kit from vintage connections that I will post about pretty soon, I have to figure out how to use some of those connectors, plastic sleeves came with the kit.
« Last Edit: September 19, 2018, 03:28:28 PM by AlekStooge »
Offline AlekStooge
« Reply #336 on: September 19, 2018, 04:07:36 PM »
I see the switch itself doesn't require a positive, only the light.
I'll switch back to the 42.
My cam chain is connected to both the cam and crank. I was worried I'd have to degree my cam over again. So I would have to pull the main shaft or which ever one you have to freeze to put back in, spilt the cases, put the O ring in, freeze the bearing, reassemble the transmission, seal the cases back up. I have to man up to it.
Offline Little_Phil
« Reply #337 on: September 20, 2018, 02:41:11 AM »
I took the chain cover off and replaced the sprocket. I remembered there was a O ring on the primary shaft behind the seal that I forgot to put in. I think I'll be fine though.Put the O-ring in. Its there for a reason from the factory.  ;)
I think I remember this. There was discussion about where that O ring goes. Part 34 here?
https://images.cmsnl.com/img/partslists/honda-cb550k-1978-usa-transmissionkick-spindle_bighu0056e4315_682d.gif
It looks to go on the shaft before the main slotted bearing is pressed on and is only replaceable if that bearing is removed/replaced. If bearing was left in place, no worries.
Part of this assy?
https://www.cmsnl.com/honda-cb550k-1978-usa_model7222/shaft-trns_23220374000/#.W6Npp_ZFyaF
« Last Edit: September 20, 2018, 02:45:12 AM by Little_Phil »
Offline AlekStooge
« Reply #338 on: September 20, 2018, 06:43:26 AM »
The O ring is part 40 it goes between the bearing and the seal. I tore the cases apart and I'm glad I did, I am getting weary of this and just want it to be over. :(
That is one of the pucks from the head. I don't know how this happened. I am not sure where to continue from this point. I am thinking of going back to square one removing everything from the cases and cleaning it.
I also removed the rotor mistakenly. I was getting bound up and I thought that might have been it but I just forgot there were case bolts on the upside. The crank moved a little so I'll have to re-degree the cam. Of course those little stupid alignment pins on the bearing are missing and I didn't hear them drop to the ground, I was conscious of them when removing the lower case. I don't even know which ones they are on a parts fiche. At least now I have done all this before so I know how to do it.
« Last Edit: September 20, 2018, 06:46:46 AM by AlekStooge »
Offline AlekStooge
« Reply #339 on: September 20, 2018, 09:26:10 AM »
Head sprocket, I disconnected the alternator rotor. Yes I will have to degree again.
I mean in terms of cleaning the engine because that rubber puck is obviously crushed up. I want to clean the cases. Do you think I will need to clean the head as well?
How do you think this puck got loose an fell all the way down?
Offline AlekStooge
« Reply #340 on: September 20, 2018, 12:54:48 PM »
 Ok I'm getting motivated again. So what you're saying is pull any rubber debris I see in and around the cases, clean it up. Then continue on, start the engine let it run for some time and any remaining debris will be in the oil pan/filter/strainer. Then clean the internals once again.
 I bought that pin as well as a set of pucks.
« Last Edit: September 20, 2018, 01:20:56 PM by AlekStooge »
Offline Little_Phil
« Reply #341 on: September 21, 2018, 02:38:45 AM »
Yes sorry part 40. It's 24.5mm o/d and slides on the shaft before the bearing. It is to prevent oil from getting between the I/d of the shaft and the area to the splines where the chain drive sprocket fits. You will see that the oil seal metal ring is a separate pressed on part (but not available separately) so in theory could leak here.
Offline AlekStooge
« Reply #342 on: September 21, 2018, 08:41:28 AM »
Glad I did, I'm just waiting for parts now.
I was looking at some of the things in the cases. First is this oil guide looks like there is a tiny bit that must have broke off at the end. Unfortunately neither David Silver or CMSNL have this part, so I don't know what I'll do if I need to replace it. Part 3
https://www.cmsnl.com/honda-cb550k-1978-usa_model7222/partslist/E++12.html#.W6UQUu_QZjo
Second is my kick start spring it looks like it will fall off the case one day. I moved it a bunch of times with the lever on and it doesn't fall off but gets very close to the edge.
Offline tanner709
« Reply #343 on: September 21, 2018, 09:13:59 PM »
Take a look at the right side cover, it may continue the same profile on that groove and spring for the kickstart = it will not fall off. Or it may have a stop to keep it pinned in there
Offline AlekStooge
« Reply #344 on: September 22, 2018, 07:14:55 PM »
Yes, thank you ;D. There is a profile on the clutch cover that blocks the spring from sliding off. Tanner, you should be more active on the forum, good insight!
Offline rballenger7
« Reply #345 on: September 24, 2018, 11:25:35 PM »
How do i search mike reicks profile to pm him
Offline AlekStooge
« Reply #346 on: September 26, 2018, 09:58:49 PM »
Update: While I was waiting for that pin to come in I've been in the garage fabricating. Made a new electric re-location pan, the previous one would allow the battery to fit under the rear gusset. I finished up the seat. I made a tab for the taillight that I will weld in once I re-drill a hole in it that is off by like 3mm.
Now those parts came in toady. I was going to button the engine up tonight. Riddle me this, how is that O-ring supposed to fit in between the bearing and the seal? It won't go onto the part of the shaft the seal is on, the ID is too small and I never took that bearing off it is pressed on or put on using some process I'm not familiar with.
Without seal
With seal
Part 40 https://www.cmsnl.com/honda-cb550k-1978-usa_model7222/partslist/E++15.html#.W6xiuu_QZjo
Offline DaveBarbier
« Reply #347 on: September 27, 2018, 05:02:18 AM »
Hey Alek, I just want to get some definitive answers. For the transmission, did you disassemble the shaft and remove the o-ring in question? You just said you never removed that bearing...I don’t get what makes you think that the #40 o-ring needed replacement.
I haven’t disassembled the tranny shafts, but I assume that o-ring goes between the inner bearing race and the collar that the seal slides on to.
When you reassemble the lower case, be sure the end of the cam chain tensioner sits in it’s little pocket in the lower case. I bet installing the lower case with the oil pan off (which I think has to be done anyway) will be fairly easy to see if the tensioner is in it’s home. Just keep an eye out, but you’ve done this before so you’ll be good.
« Reply #348 on: September 27, 2018, 06:46:04 AM »
Email is jmrieck2@gmail.com
Offline AlekStooge
« Reply #349 on: September 27, 2018, 07:17:23 AM »
Correct I never removed that bearing nor do I know how... I bought all new O-rings, seals, gaskets so I figured I'd replace them all. I guess if the old one is still there, then I don't need to worry about it and I could let that one go. I'm just being meticulous, left over engine parts scare me.
Cam tensioner pocket, got it! ;)
