Author Topic: Why bother with the bearing retainer rings on the wheels?  (Read 1614 times)
Offline drumstyx
« on: June 21, 2016, 04:08:44 PM »
My bearings were in there so tight, there's no way they needed the retainer rings to stay in. Every other bike I've worked on was just a press fit (and even then, some not even as wedged as these were).
Offline Lostboy Steve
Re: Why bother with the bearing retainer rings on the wheels?
« Reply #1 on: June 21, 2016, 05:56:03 PM »
I have had this thought come to mind... but I figure they must be there for a reason, and I refuse to be the guy to test out leaving them off.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Rookster
« Reply #2 on: June 21, 2016, 06:13:01 PM »
The retainer is there so the bearing does not get pushed out when installing the opposite bearing.  The spacer gets sandwiched in between so one of the bearings has to be solid otherwise the entire sandwich could shift and cause your disk to be too far or too close to the fork leg.  It isn't to hold the bearings in but to get the correct wheel spacing between the forks.
Scott
Offline Bodi
« Reply #3 on: June 22, 2016, 05:05:44 AM »
The retainer ring is all that locates the wheel on the axle. You really, really, REALLY, do not want to go without it.
Any wheel hub not needing a bearing retainer has a different design, there are several. The design of our Honda hubs with one floating self-aligned bearing absolutely requires the other bearing to have that retainer.
Offline chewbacca5000
  • I polish covers!
« Reply #4 on: June 22, 2016, 05:45:32 AM »
I used to have a powdercoat oven and would put the whole wheel in at 300 degrees and they use pit possie bearing removal tool and they all cam out easily.
Getting that hub good and hot made the difference.  I would use welding gloves to hold the wheel.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #5 on: June 22, 2016, 05:47:44 AM »
I've seen lots of newer wheels with snap rings instead of the screw in retainers. Similar to our fork legs.
--Evan
1975 CB750K "Rhonda"
« Reply #6 on: June 22, 2016, 09:05:40 AM »
Morris wheels use NOTHING to hold the bearings in..
Neither do spool hubs and many other wheels.
the wheel spacers however, do previous nt side movement.
« Reply #7 on: June 22, 2016, 09:18:10 AM »
Safety might be reason.
There are forces in all directions going through the front end.
I would hope they help keep the bearing races in alignment, as well as provide some measure of weatherproofing.
(factory installed bearings were not completely sealed, IIRC)
« Last Edit: June 22, 2016, 09:29:26 AM by flybox1 »
« Reply #8 on: June 22, 2016, 09:20:35 AM »
Morris built magnesium. Roadracing wheels..pretty sure safety easy a concern..
« Reply #9 on: June 22, 2016, 12:48:09 PM »
Retainer yes, lock it by punch marks - no. The new retainers I put in after bearing replacement are only screwed in. I locked them very hard with deep punch back in the 80's. I had to use brutal force to remove them. The rear retainer for hub is not locked at all, used copper grease when the threads were to damaged after all holes after punchs. OEM + replacement.
The bearing must be seated firmly, retainers are a part of the package on axle with bearings, spacers all torqued together in a rigid packages . It must be very flimsy otherwise or the inner race might get more sideway forces than outer wich will ruin the bearing quicker, right?
Offline drumstyx
« Reply #10 on: June 22, 2016, 05:26:41 PM »
No way I'm re-punching these buggers. Even drilling them out, the front one was destroyed, and one of the rears will have to have some burrs ground off. The one with the round holes is still pristine though for some reason.
Offline Ricky_Racer
« Reply #11 on: June 22, 2016, 07:38:04 PM »
Yeah, Frank, my Cambray (Campbray) CB750 wheels don't use a rear bearing retainer. Freaked me out at first, but I guess it's just the way it is. RR
