Author Topic: Motor rebuilt by someone else  (Read 1386 times)
Offline lightsareout
« on: July 31, 2016, 06:01:35 PM »
I recently picked up a CB550 74 frame/motor that also came with another 75 motor.  The 74 motor is leaking oil in many areas and would need a full rebuild before I would invest my time putting it into my build.  The 75 motor looks to have been rebuilt recently but the previous owner did not have any background on it.  What testing and investigation can I do on this motor before proceeding with it on the bike?  I think it was recently rebuilt due to the liquid gasket along the seams and no oil in it.  I was going to check the compression on it but not sure what else to check to decide if I'm good to go or should crack it all open.
Thanks for any advice!
Offline MoMo
  • Ride like you're invisible
Re: Motor rebuilt by someone else
« Reply #1 on: July 31, 2016, 06:10:44 PM »
You can do a leak down test.  Hope the liquid gasket you''re referring to isn't silicone...Larry
« Reply #2 on: July 31, 2016, 06:16:41 PM »
its grey, isn't hondabond white?
Offline chewbacca5000
  • I polish covers!
« Reply #3 on: July 31, 2016, 06:18:21 PM »
Liquid gasket is not a good sign.  Favorite tool for hack jobs.  I would do a compression check on both motors and pick the one with the best compression.  Then replace the gaskets on that one.
« Reply #4 on: July 31, 2016, 06:27:21 PM »
i should clarify the grey sealer is oozing out between the crankcase halves and around the oil seals, I don't see any on the top half.
Offline thirsty 1
« Reply #5 on: July 31, 2016, 06:41:05 PM »
Remove the plugs and install a oil psi gauge. Spin it over with the starter. You should get around 20-30 psi. Check comp with and without oil in the cylinders. Check the valve timing before doing anything. Set the ignition timing ie: points. Check the valve clearances
Offline MoMo
« Reply #6 on: July 31, 2016, 06:43:35 PM »
good to hear.  Gasgacinch is grey, that should not create a problem on the lower end.  I  once bought a 750 on which the lower end had been "rebuilt". less than two miles the lower crankcase started to break.  As mentioned earlier leak down will give the most accurate condition of the top end...Larry
« Reply #7 on: July 31, 2016, 06:45:03 PM »
thank you for the tips!
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #8 on: July 31, 2016, 06:45:59 PM »
Hondabond/permatex are both grey.
Used perma grey on my clutch cover.  Seems to have done the job.  350 miles and holding.
Offline thirsty 1
« Reply #9 on: July 31, 2016, 06:57:55 PM »
one more. Make sure it actually has an oil filter installed.
