Author Topic: K2 Broken, then repaired top triple clamp.  (Read 7743 times)
Offline Old Moe Toe
« on: August 06, 2016, 12:42:04 AM »
I had a badly bent K2 frame straightened out and I picked it up yesterday from the frame straightener. Was impressed that he managed to get the front and rear wheels in perfect alignment considering how far out they were beforehand.
However I was disappointed that he broke the top triple when removing the front end. He explained that he had repaired the breakage and that the right hand side of the clamp had also been broken and repaired at some stage during the bikes life as well. He pointed out where that repair had been made.....double disappointment.
 I am not really keen to re-use a triple clamp that has been broken in one place, let alone two. Mr frame straightener was of the opinion that it should be ok but he is not the one who will be riding the bike.
 Just looking for a few opinions here. Would I be crazy to even think of using this clamp again? To me the first repair job which was done prior to my ownership of the bike looks to have a hairline crack in it if you look closely. The more recent repair (shinier one) looks ok but it is hard to know what is going on inside the metal.
These unicorn triple clamps only suit the K0,K1,K2 and are pretty hard to find second hand and are generally quite pricey. I see that Yamiya sells a replica item but they are super pricey.
I get the feeling this type of clamp was badly designed from the start as they have the "D" shaped washer that the pinch bolts pass through so you do not break the clamp if you over tighten it.
Here are 3 pics. One shows the whole clamp, other 2 are close ups of each side. Left side one is a bit blury but there does seem to be a hairline crack.
Thank you
Offline 540nova
Re: K2 Broken, then repaired top triple clamp.
« Reply #1 on: August 06, 2016, 03:19:28 AM »
Get a nice billet replacement from Cognito Moto, Dime City Cycles, or wherever. Not worth risking your neck for originality.
1974 CB450, 2006 CBR1000RR
Offline somesuch
« Reply #2 on: August 06, 2016, 06:51:08 AM »
I remember seeing one here for sale for cheap, but can't seem to find the post...
Offline beemerbum
« Reply #4 on: August 06, 2016, 08:11:56 AM »
What is the correct torque setting for bolts on this type of clamp? I have a 1971 K1 and have just removed the fork tubes.
Offline Swoop
« Reply #5 on: August 06, 2016, 08:40:55 AM »
Offline somesuch
« Reply #6 on: August 06, 2016, 08:49:00 AM »
Offline grcamna2
75' CB400F/'bunch o' parts'
« Reply #8 on: August 06, 2016, 09:34:57 AM »
Buy it Moe!
Offline beemerbum
« Reply #9 on: August 06, 2016, 12:11:12 PM »
So is there a torque value on the bolts so as to not overtighten and crack?
« Reply #10 on: August 06, 2016, 01:02:24 PM »
I've never used my torque wrench on it, just tighten by feel.
The triple tops that I've seen broken are typically missing the D-washer, which acts as a spacer.
Offline grcamna2
« Reply #11 on: August 06, 2016, 03:05:33 PM »
I've got a couple extra washers and I take one as an example w/ me to the hardware store to match up for the correct thickness and that way I make-up a few spares to keep from cracking that good hard(and brittle cast aluminum)oem original top triple.The other thing to be very careful with is removing the top triple,use plenty of WD40 and whatever you do don't use a steel hammer or drift punch.
Offline Johnie
« Reply #12 on: August 06, 2016, 03:30:09 PM »
Torque setting for that top bolt with the "D" washer is 6.5 - 9.4 ft. lbs. I use it on all my top fork bolts.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Old Moe Toe
« Reply #13 on: August 06, 2016, 03:47:29 PM »
This one is $110. (Mine)
http://forums.sohc4.net/index.php/topic,159356.0.html
that's the one I was thinking of!
PM sent . Sorry for the delay, there is about an 18 hour time difference here.
« Last Edit: August 06, 2016, 03:52:45 PM by Old Moe Toe »
« Reply #14 on: August 06, 2016, 04:31:38 PM »
Hey Moe, to soften the blow I'll give you 50 bucks for your dodgy one, if you're interested? Cheers, Terry. ;D
Offline beemerbum
« Reply #15 on: August 06, 2016, 05:21:36 PM »
Thank you. I never realized the upper triple is so prone to cracking
Offline Old Moe Toe
« Reply #16 on: August 06, 2016, 05:48:59 PM »
I wouldn't use it.  Here's one for $127, hard to find cheaper that that.
http://www.ebay.com/itm/Honda-CB750-Triple-Tree-CB-750-Top-Clamp-69-72-Unicorn-sandcast-/172267768536?hash=item281bf58ad8:g:EuMAAOSw-KFXf-yn&vxp=mtr
Thanks for the tip Steve. The downer with that is the postage the seller has quoted $114 AU. A lot of ebayers really sting you for unrealistic postal charges. Carpy sent me a 4 into one exhaust for cheaper than that guy will send a triple clamp !.
Offline Old Moe Toe
« Reply #17 on: August 06, 2016, 05:53:23 PM »
[/quote]Hey Moe, to soften the blow I'll give you 50 bucks for your dodgy one, if you're interested? Cheers, Terry. ;D
[/quote]
I'll see how I go Terry. Was rather hoping you would have chimed in saying you had a box full of these clamps and could post it in one of those overnight bags dirt cheap.
« Reply #18 on: August 06, 2016, 06:23:48 PM »
Ha ha, well I've got a good one for my K0, but a busted one on my K1, so was hoping I could get yours welded up? Anyway, up to you mate, my offer's still good. Cheers, Terry. ;D
« Reply #19 on: August 07, 2016, 10:17:23 AM »
Sorry to hear that.  Let me know if the other members offer doesn't pan out, I think I have a spare.
Offline rotortiller
« Reply #20 on: August 07, 2016, 12:35:14 PM »
I've run a properly welded tree on my H1 triple for years and it takes the stress fine-many wheelies and upgraded front calipar that will lift the rear wheel. So long as it was V'd out / jig''d and repaired by a competent welder you should be good to go. It's done all the time and a good weld can be stronger than the original.
rt
Offline grcamna2
« Reply #21 on: August 07, 2016, 01:02:28 PM »
rt
preheat it and then tig weld.
Offline 01Thomas
« Reply #22 on: August 07, 2016, 02:15:03 PM »
I have several such clamps for sale... That was probably my advert that someone mentioned having seen but now can't find it.
For the record I also have later style clamps for sale.
regards
Thomas
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
Offline Swoop
« Reply #23 on: August 07, 2016, 03:07:12 PM »
I will yeild my offer to the two that have followed mine.
Seems to be a theme for me.
Cheers
Offline somesuch
« Reply #24 on: August 07, 2016, 10:54:32 PM »
To anyone that wants a broken triple clamp (Terry?), they can have mine for the price of shipping, free if you pickup it up in Santa Clara.......just have to take it off the bike one of these days
