Author Topic: 1973 CB500 Forks size and colouring  (Read 2065 times)
Offline cantarauk
« on: August 22, 2016, 03:36:25 AM »
Hi,
There are a lot ok knowledgeable people on this forum which is a little intimidating but you have to start somewhere so please excuse any silly questions from here on in. All advice and knowledge exchange is most welcomed
I have done some research and have read somewhere that the CB500/4 have shorted (different) forks on the front and back from that of the CB550. Would someone confirm this and also advice what the sizes are as well as recommend some upgrades. Currently Hagon has caught me eye and I am looking at the all black option for the rear. For the front I may stick to stock and just do some maintenance or rebuild on these.
The staying on the subject of the front forks would it be possible to anodise the inner tube black. Is this a possibility ? and if not what are the recommendations to create a all black from fork.
G
Another question on the from forks that I am thing about doing but would like any advice
Offline cantarauk
Re: 1973 CB500 Forks size and colouring
« Reply #1 on: August 22, 2016, 05:06:26 AM »
Thank you for the reply. Think I am going with the powder-coat option for the lowers and then use some sort of tight fitting sleeve that will fill the cap between the clips and the lower yoke and then use gaiters. This seems the best option for now.
Offline cantarauk
« Reply #2 on: August 22, 2016, 06:29:46 AM »
Ahh ok I see that from some images. So may have to get some other gaiters as I am removing the headlight ears as I am putting drop bars on with a short headlight bracket for non-standard headlight
Offline cantarauk
« Reply #3 on: August 22, 2016, 07:19:32 AM »
That is perfect. Thank you very much
Offline jonda500
« Reply #4 on: August 22, 2016, 07:54:22 PM »
All 500,550 and most 750 fork lowers are the same length and have exactly the same mudguard/brake arm mounting points. Any SOHC4 500/550 forks will fit on any SOHC4 500 or 550! (They only changed a little internally).
750 forks have longer fork tubes.
John
A starter clutch thread:
« Reply #5 on: August 22, 2016, 08:11:55 PM »
I think some high end bike suspension tuning places, have a black treatment for the fork tubes..
