Author Topic: Where does this go?  (Read 1334 times)
Offline labrat
Where does this go?
« on: September 24, 2016, 02:38:31 PM »
The switches were kind of trashy on the insides I decided to clean them up. This little metal cup fell out and I'm not really sure from where.  I found a nice post on the forum with pic's of the insides of them but there's no picture of it. And I don't see where it goes or serves a purpose. Have never posted pic's, might not get it done on my first attempt. Anybody have any ideas where this goes?  TIA!
Offline eigenvector
Re: Where does this go?
« Reply #1 on: September 24, 2016, 03:00:59 PM »
Wild guess - horn button.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline sweatshirtolympics
« Reply #2 on: September 24, 2016, 03:43:29 PM »
no idea man Im sorry. I havnt dived into restoring my switches yet. goodluck
« Reply #3 on: September 24, 2016, 04:15:59 PM »
What year and model of bike and do you know which control either left or right. I wonder if a spring went under that cap--Hmm
Offline labrat
« Reply #4 on: September 24, 2016, 06:21:08 PM »
It's a K1 750, original switches.
Offline Kevin D
  • SE Michigan
« Reply #5 on: September 24, 2016, 06:26:19 PM »
Is there a dab of solder inside the cup?
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline labrat
« Reply #6 on: September 24, 2016, 07:06:35 PM »
Possibly.  The outside is smooth and there is a slight indentation in the center but there's no real sign of wear like something caused it. The inside is relatively smooth but rougher than the outside with a couple of places that could be excess solder. It's possible the whole thing is solder.
Offline Kevin D
  • SE Michigan
« Reply #7 on: September 25, 2016, 04:50:00 AM »
Is there a loose wire in there somewhere?
Have you checked the switches with an ohmmeter?
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
Offline labrat
« Reply #8 on: September 25, 2016, 06:46:37 AM »
To do that I need to figure out which switch positions or pressed button allow which wire combo's to pass current?
Offline Kevin D
  • SE Michigan
« Reply #9 on: September 25, 2016, 09:29:44 AM »
Yes, and you will need to read and understand a wiring diagram too. Lucky for you, the Oldman Honda page has a nice wiring diagram for CB750k1 that you can simplify to see only what you are after.
       http://oldmanhonda.com/MC/MC.html
All that said, I don't know what the thing is. It looks like a button  contact, maybe a wire was soldered to the back.
Left or right side switch?
A picture of the bike and switches might also be helpful.
« Last Edit: September 25, 2016, 10:02:36 AM by Kevin D »
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
Offline halllzy
« Reply #10 on: September 25, 2016, 01:57:02 PM »
Looks like a high/low beam contact
Sent from my Nexus 6P using Tapatalk
