Author Topic: finally got my cb750  (Read 2438 times)
Offline cb750photog
« on: September 25, 2016, 04:56:12 PM »
hello everyone. so glad i found this forum.so by chance i came across a 73 CB750 for almost nothing its in rough shape but i want to do her up as a brat style bike anyway. it looks like one of the other owners did some cool stuff with her she has a 4 into 1 exhaust a oil pressure gauge an oil radiator and many other aftermarket parts.
Offline rocket johnny
Re: finally got my cb750
« Reply #1 on: September 25, 2016, 05:51:19 PM »
sounds like a fun find !   any pics ?
« Reply #2 on: September 25, 2016, 08:39:18 PM »
Welcome
Offline cb750photog
« Reply #3 on: September 25, 2016, 08:46:42 PM »
I have to get some pics soon.I was rear ended on Friday coming home from work in my 76 Mercedes and been trying to deel with that. but maybe Tuesday I will get some time to get some pictures.
« Reply #4 on: September 25, 2016, 09:00:22 PM »
Welcome aboard , looking forward to the pics .
« Reply #5 on: September 26, 2016, 05:23:57 AM »
Welcome from VA.
Offline cb750photog
« Reply #6 on: October 03, 2016, 04:17:42 PM »
This is  my bike as I got her. Not much right know but hope it's cool when I am done with her. Just got my tank that I ordered off eBay it's in good shape no real rust on the out side the inside looks like it is just starting to get a little surface rust. Any suggestions on how to get rid of that before it becomes an issue. I will try to get some pics of the tank in a few days.
« Last Edit: April 22, 2018, 02:47:12 PM by Glenn Stauffer »
« Reply #7 on: October 03, 2016, 06:20:47 PM »
Your frame. Has had some tubing and the brace cut. Out under the tank.
Can be fixed, some run them like that.  I cut for access to the top end.
Offline cb750photog
« Reply #8 on: October 03, 2016, 08:17:18 PM »
Yeah I noticed that too. Figured I would weld in removable bars there so I could have the easy access and still maintain some of the frames rigidity. Here is a pic with the new tank . I got out my high-powered flash light and looked in it again and it's not rust in it just some sediment that I will need to clean out.
« Last Edit: April 22, 2018, 02:48:20 PM by Glenn Stauffer »
« Reply #9 on: October 04, 2016, 06:34:20 PM »
I make a weldless kit.. But first step is to weld in new tubes and make a brace.
 Then cut the new tubing..
Offline cb750photog
« Reply #10 on: October 05, 2016, 03:34:59 PM »
That sounds interesting. Do you have any pictures of it? I was looking at another one that you wield in bungs and they screw together. But the wield less idea sounds cool.
« Reply #11 on: October 05, 2016, 04:36:11 PM »
Click here to see the one I recently installed on my K3...
http://forums.sohc4.net/index.php/topic,156311.275.html
Offline cb750photog
« Reply #12 on: October 05, 2016, 05:10:57 PM »
Wow that looks awesome.how much are they? I think I have the same air filter with my bike as is on yours but the rubber on mine is hard as a rock. So if I can get new rubber I'll clean it up and use it.
« Reply #13 on: October 05, 2016, 07:15:15 PM »
Pm sent.
« Reply #14 on: October 05, 2016, 07:21:53 PM »
Yes, that is a vintage Henry Abe air filter that can sell for good money on eBay if in great condition. Have no idea where to find replacement rubber.
« Reply #15 on: October 05, 2016, 08:42:09 PM »
Show a oic of the oil tank side , we can probably id the 4-1 pipe..........
Offline cb750photog
« Reply #16 on: November 12, 2016, 12:07:20 PM »
So finally got a chance to get the bike out and get some pics of it. here is the oil tank side.thank you all for your help.
« Last Edit: April 22, 2018, 02:50:23 PM by Glenn Stauffer »
« Reply #17 on: November 12, 2016, 03:15:36 PM »
welcome  Your bike has some neat old parts.  That blue frame reminds me of one I used to have.  You can see pictures here.
http://forums.sohc4.net/index.php/topic,80592.msg901995.html#msg901995
Mine was an early k2.  Have you checked your frame numbers yet?
Offline cb750photog
« Reply #18 on: November 15, 2016, 05:02:01 PM »
If I remember correctly when I looked up my frame number is was a k2. I like what you did with your looks cool.
« Reply #19 on: November 17, 2016, 05:47:49 AM »
 It has a K2 top unicorn upper bridge and instrument straps.
« Reply #20 on: November 17, 2016, 09:43:12 PM »
Looks like a 73-76 motor or at least the head.
 Got a front view of the pipe ?
I think the rubbers in the aircleaner are just the stacks out of the stock airbox.. I replaced the foam in mine with sheet foam from i think UNI..
Offline cb750photog
« Reply #21 on: November 18, 2016, 04:56:55 PM »
When I looked up the numbers on the frame and engine they both said they were 73. I think the front fork and brake are off a 69 or so. It has the t bracket. No picture of the front yet but will try to get some tomorrow.here are a few more of it though.
« Last Edit: April 22, 2018, 02:51:12 PM by Glenn Stauffer »
« Reply #22 on: November 18, 2016, 05:38:38 PM »
I dont think it was mine then, kinda bummed, would love to know what happened to that old girl...but anyway, looks like you got some really solid and cool project material!
