Author Topic: CB750 K2 '72 Throttle linkage  (Read 812 times)
Offline wingingit2
« on: October 19, 2016, 06:29:10 PM »
I am working on a CB750 K2 and the carbs have me baffled. I haven't pulled them out yet. The most prominent problem is that at idle when I roll the throttle backward there is a spring loaded mechinism, fine. But when rolling backward the idle drops and the bike can die. I noticed that only the right 2 carbs ( #3 & #4) will change. Syncing has helped a little bit. The manual is no help on how the throttle linkage is assembled and how it works.
Thanks in advance for any help.
Lady Luck Prefers the Prepared
Re: CB750 K2 '72 Throttle linkage
« Reply #1 on: October 19, 2016, 08:20:41 PM »
 Not really getting the question but maybe there is something broke on one side. Pulling the gas tank which is very easy should bring the carbs in full view while still mounted for a better inspection.
Offline Gene
  • Chat enuf you too can be a
« Reply #2 on: October 19, 2016, 08:57:11 PM »
Check the spring - sounds like something is blocked or broken with that part of the mechanism. Maybe a "stop" is no longer in place for deceleration.
*1973 CB750K3 (Bow)
Offline wingingit2
« Reply #3 on: October 20, 2016, 08:58:12 AM »
Getting ready to pull the carbs. It seems that the throttle shaft is moving in the bore. Do these have bushings for the shaft??
« Reply #4 on: October 20, 2016, 01:55:24 PM »
 Best thing to do is look at a parts diagram. No bushings per say. These are the easiest carbs to work on, they are a real treat compared to some.
« Reply #5 on: October 20, 2016, 05:50:07 PM »
There is a pin or two driven in to the shaft, to prevent side movement.... Tricky to get out and hard to see..so occasionally someone trys to drive the shaft out and cracks the pivots on the plate the carbs bolt to. Be aware of that if trying to disassemble shaft.....or notice cracked pivot bosses.
