Author Topic: K and N pod size?  (Read 929 times)
Offline Taycodog
K and N pod size?
« on: February 21, 2017, 01:17:01 PM »
I know the topic has been beaten to death but I have question I'm hoping someone can answer . I am looking at putting a set of pods on my '77 cb750 with PD A1 carbs I measured the outside diameter of them and it's 46 mm but the pods they recommend ( RC-2314) inside diameter is 40 mm is that a really tight fit or have I got the wrong measurements/pods? . I know most don't recommend going this route. But I want to try ,   I just hate the look of the box and I want the space. Thanks.
'76 CB750 K
'77 CB750 K
'73 CL 350 scrambler
'69 BSA lightning
Offline Pat_at_APE
    • APE Race Parts
Re: K and N pod size?
« Reply #1 on: February 22, 2017, 09:38:21 AM »
The pod filter set we offer is 42mm ID.  They will fit your carbs.   They are round (not oval as pictured).  They work well and you can clean and re-oil them.
You can find them here:  http://cbrzone.com/sohc.html
Regards,
Pat at APE
« Reply #2 on: February 22, 2017, 10:25:10 AM »
  Good thing Pat jumped in there with an answer, everybody else would be afraid to jump in. What kind of oil should I use on them  ;D ;D
« Reply #3 on: February 22, 2017, 10:32:33 AM »
KN has special oil in spray can. My worked fine last time 2 years ago. Bought it 1984 when I gave pods to my carbs (VM29 Smoothbores).
Cleaner too. this last long. Sorry, I think I used it last year too when my new carbs got new KN pods :)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #4 on: February 22, 2017, 11:18:37 AM »
Atf helps them stay that reddish color  ;D
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #5 on: February 22, 2017, 02:45:51 PM »
Pat is correct - 42mm ID.
Starting out with dry pods can be a good move - then when all else fails to correct your over-lean condition you can always add some oil to richen things up a bit  ;D
Build threads:
1977 CB750 F2
1958 Norton Model 99
