Author Topic: Wheelies!!!! - a question not clips of them  (Read 3658 times)
Offline eigenvector
« on: March 23, 2017, 04:51:35 PM »
There are two things that I regret not learning in my younger days - doughnut burnouts and wheelies.
I'm old enough that dropping the bike while learning how to wheelie would probably end up with me in traction.  That said - how many of you have the skills to wheelie their CB7 or 550?  How do the old gal's do in that regard - seems like they'd be a bit too heavy and the 550 doesn't seem like it would have the power to do a doughnut burnout.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
scrapvalue
Re: Wheelies!!!! - a question not clips of them
« Reply #1 on: March 23, 2017, 05:30:19 PM »
I have never actually tried doing a wheelie, just because I never wanted to torture the old girl that bad.
But being a motocrosser my whole life, wheelies are pretty much a part of riding every other bike I own or have owned.
I have a 1995 BMW R1100GS that does amazing wheelies.
Offline Ridem32
« Reply #2 on: March 23, 2017, 06:38:07 PM »
I was also a motocross rider as a kid. I had a 1975 cb750 when I was 15 years old. I was dating the girl I'm married to now of 37 years. I could wheelie mine with her on the back popping it up in first and shifting thru 3rd gear in the air.  The thing that helped the most was heavy duty clutch springs. And I had open drag pipes back then.
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #3 on: March 24, 2017, 04:30:37 AM »
I have always tried to avoid wheelies on any bike just because I did not want to replace blown out fork seals. Ever so often I have done an unintended wheelie by ripping the throttle open too hard. Rear brake controls it.
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
« Reply #4 on: March 24, 2017, 05:13:42 AM »
  I used to have a favorite little bump/hump in a road in downtown Kalamazoo on a bridge between two ponds that was perfect for a little front wheel float in first or second coming off the stop sign and a combo of throttle and clutch feather. Still can't resist when I go over it ;) No big power wheelies for me though.
« Reply #5 on: March 24, 2017, 06:07:37 AM »
There was a fellow  here named BOXKNIFE and he did wheelies. I asked him how he did it since these bike are front heavy. He said he got a bouncing motion going until he could pull the wheel up. I could get the wheel to get light on the pavement on a 1st to 2nd shift. Not a wheelie by any means.
Online Stev-o
« Reply #6 on: March 24, 2017, 06:49:35 AM »
My little RD350 is a wheelie machine!  [I avoid em on the H1]
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #7 on: March 24, 2017, 09:22:51 AM »
I was never any good at wheelies either.  Didn't matter what I was riding!
Going completely airborne sometimes worked out okay.  Not everytime, just sometimes.
« Reply #8 on: March 24, 2017, 09:24:56 AM »
All of my modern bikes have power wheelied at one time or another, unintentionally.  I don't really care to clutch wheelie.
« Reply #9 on: March 24, 2017, 09:40:27 AM »
You need to use the clutch (a good clutch) if you want to get the wheel up enough to ride a wheelie and not just pop the wheel up a few inches. Roll along at 25-30mph, pull the clutch, grab 1/2 throttle and dump the clutch. Keep the rear brake pedal close! It helps to have a little more juice than stock too.
Offline Ridem32
« Reply #10 on: March 24, 2017, 12:14:14 PM »
Once you learn how most all bikes can wheelie   Once you reach the balance point all bikes will set in the balance mode and just work the throttle lightly and when speed picks up shift into the next gear.  I learned how to wheelie a bicycle at a very young age. Then my fist bike was a 1970 mini trail 50.  I could wheelie it but had to drag my feet behind it.  On a  Honda automatic like the trail 50 or 70 when u put them in first gear and hold the shifter down u can rev the motor then release the shifter with your foot and it's just like popping a clutch.
« Reply #11 on: March 24, 2017, 02:46:23 PM »
I bet Brent can pull an epic horn mono.
Offline jgger
« Reply #12 on: March 24, 2017, 07:21:25 PM »
Dirt bikes are the easiest to wheelie, my old Montesa 250 could wheelie for days. I would blib the throttle with my butt back on the seat and when it came up I would slide slightly forward. Start in 1st then shift all the way up to 5th until I got bored. I too don't like clutch wheelies, you have much less control when it comes up.
If you are trying to learn then an up hill grade makes it easier to find the balance point.
Offline GV1390
  • Express Gratitude.
« Reply #13 on: March 24, 2017, 07:29:54 PM »
+1!
I wouldn't advise putting our old bikes through the abuse in doing a wheelie especially since it lacks power. My MV Agusta would clutch up in 3rd at the bottom and hold it to the top of the gear without ever an issue. Hovering that rear brake is essential.
08' Ducati S4RS, 71’ CB500, 71' CL350, 72' R90/6, 16' Ural Gear Up & 02' ZRX1200R.
Offline Desert-SOHC
  • It's old
« Reply #14 on: March 24, 2017, 08:22:12 PM »
Never really did any on the 750, used to wheelie the 82 CB900F all the time though.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
« Reply #15 on: March 24, 2017, 10:00:19 PM »
 No, but my first ride on a 750 after 20 years off one was inspiring. It had a huge bog and refused to run right, in my frustration I cranked the throttle and held it open, suddenly it got fuel and made the hardest launch I ever did on a 750, I was hanging on for dear life and it almost got away from me. it may have carried the wheel, I have no idea, but I was pretty sure I was about to get off the hard way and really worked hard to lean back into that throttle grip to slow her down.
« Reply #16 on: March 25, 2017, 03:48:13 AM »
Me too! I've only done a couple of unintentional power wheelies on mine, but it's easy to get the front end light with that big torquey boxer!
Back to SOHC4's, KGhost (Tim Kasper) is our best resident CB750 wheelie guy, someone posted a pic of him pulling up the front wheel on his K3(?) @ 60MPH a few years back, but he's a pilot, so probably more used to taking off with his front wheel in the air. Cheers, Terry. ;D
« Reply #17 on: March 25, 2017, 04:58:35 AM »
 I've got an old 1981 Yamaha YZ250 still in the barn,last year of air cooled, that I got in 1985. Its got a ported cylinder etc on it and has what is like a light switch power band. It will go from humble to wheelie in most gears very quickly. Most  of my friends who rode that bike back in the day usually came back with the rear fender between their legs and in much pain from flipping it over  ;) Love those Answer handlebars,they don't bend  :)
Offline eigenvector
« Reply #18 on: March 25, 2017, 07:35:51 AM »
I said I never learned how to wheelie and I meant it.  That said, the very very first time I ever rode a motorcycle, and Honda Fatcat it bucked me off the back and dropped me on my tail.  You wouldn't think a bike like that could do that.
And I hear you Don - my Sabre is the same way, those vacuum carbs when then not in tune can get scary uncontrollable when they start to bog.  I have done a straightline burnout on that.  Wasn't just the pavement I left a skidmark on:)
Rob
1977 CB550K
1983 VF750S Sabre
Offline b52bombardier1
« Reply #19 on: March 25, 2017, 07:55:21 AM »
Does anybody worry about the oil pump pickup sucking air when doing wheelies?  Can the engine lose oil pressure?
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
« Reply #20 on: March 25, 2017, 03:57:04 PM »
Ha ha, I've still got my Honda XR500RE Eric, the RE was a whole new design to try to bridge the gap between 2 stroke and 4 stroke enduro bikes and they dumped the old 26 BHP XL engine for a 41 BHP hotrod, so in a bike that weighs less than I do, it's way too easy to get the front wheel up, up, and over! ;D
« Reply #21 on: March 27, 2017, 08:24:28 AM »
Rick
No there's more than enough oil (and the motor is not upside down) and how long are you planning to pull a 12 0'clock?
