Author Topic: First Restoration 78' 750F  (Read 1648 times)
Offline survivor1911
« on: April 09, 2017, 10:18:00 PM »
So this is my first bike restoration
Next to my high school there is a small shop and I saw this old gal wasting away to nothing for a while so I told myself, man I gotta save her. So I did, I got the bike with whats on it,  the pod air filters and the tach/spedo assembly, owners manual and title for $200
It is a 1978 Honda CB750F Super Sport that has been sitting for about 10 years, 9 under a canopy and 1 out in the elements where I found her. She seems to be in decent condition, mostly surface rust with faded and chipped paint. Tach and spedo were not on the bike, the guy had them inside the shop so no one would steal them, tach reads just about 20,000 (the shop owner said he thought it had 35,000 so it was a pleasant surprise when I saw under 20)
So first thing is to get the thing running, doesn't seem like it will need to much to do that, got some new oil in it already and gonna start work on it soon, looking to put no more that 3000 in to it and have it done in about 2 years, not in a big hurry.
The pic at night by the dumpster was the night before I took 'er home.
Any advice would be well appreciated!
« Last Edit: April 11, 2017, 10:59:50 AM by survivor1911 »
Offline DaveBarbier
Re: My First Bike Restoration
« Reply #1 on: April 10, 2017, 04:46:24 AM »
Nice bike, after Cal's recommendation I'd just say to get a shop manual. Either download one that's in the downloads section here and print it up, or buy one. Did it come with the tank? If so, that's got to be cleaned out. I'd focus on the 3k mile service and maybe inspect the electrical connections. I'd probably remove the ground points, clean them and reinstall too. Inspect tires, brakes and suspension thoroughly.
Hope it turns out to be a quick process!
Offline kap384@telus.net
« Reply #2 on: April 10, 2017, 06:54:47 AM »
Keep us updated!
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
« Reply #3 on: April 10, 2017, 09:50:01 AM »
The engine was not seized thankfully, If there is rust inside I assume its fairly minimal because all access to the inside was well covered and sealed (though all seals held they will be replaced) and there was almost a full reservoir of oil which I changed with new stuff to keep her happy (I have the original pod air filters but the guy took them off so no one would take them, so they can be cleaned and the throttle on the carb wont move but the choke will). I kick it over every so often to keep everything moving. I checked plugs and they are good but the ignition is not complete at the moment so I cant check for a spark quite yet. And the bike came as seen, no tank, covers or seat and stuff.
List of priorities
1. Complete ignition system (Wiring seems all there, gotta clean contacts and get a key ignition)
2. Get a spark
3. Replace all cables (choke,brake,clutch)
4. Replace brake/clutch levers
5. Start her up
« Reply #4 on: April 11, 2017, 10:58:59 AM »
Just got a new battery for it, filled and charged up, hooked it up, nothing working right now so next step is to properly rewire everything.
Starting to gather parts, ignition, cables and getting her in condition to run.
Re: First Restoration 78' 750F
« Reply #5 on: April 12, 2017, 10:05:29 AM »
Could someone maybe also toss a full wiring schematic my way? Ive got all the wiring pulled apart and separated (lights, horn, bar switch connections and all), but having trouble finding what goes where.
