Author Topic: Starter Clutch  (Read 5415 times)
Re: Starter Clutch
« Reply #25 on: April 23, 2017, 08:22:58 AM »
Another worthwhile service to fix another NLA issue - if it works!!
Offline mcswny
Re: Starter Clutch
« Reply #26 on: April 24, 2017, 09:42:49 AM »
Pretty awesome!
FWIW, I'm waiting for a new gasket which is coming today to see if that new gear I got works better. It definitely was infinitely more smooth than the one I pulled out.q
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Offline mcswny
Re: Starter Clutch
« Reply #27 on: April 24, 2017, 06:22:39 PM »
Just buttoned up everything and it seems good good (for now)!
Looks like the gear needed to just be replaced with a less worn one.
1972 CB750 K2
1975 XL250
198 XR80
Re: Starter Clutch
« Reply #28 on: April 24, 2017, 11:40:34 PM »
Problem with machining the surface is that is doesnt take a lot of wear to make the gear undersize and not work. If you machine the gear you will probably need oversize rollers as there is not a lot of movement between slip and engage.
Just for interest I have a NOS gear sat on my desk here in England, I could be persuaded to part with it for enough beer vouchers
Re: Starter Clutch
« Reply #29 on: April 25, 2017, 07:23:16 PM »
I removed .006" off the OD of the hub, so to retain the same roller position on the ramps of the clutch would require .003" larger rollers; however, it appears the ramps have enough "travel" that even more might be possibly removed without requiring oversize rollers?
Re: Starter Clutch
« Reply #30 on: April 25, 2017, 08:20:19 PM »
Doesn't seem like much and it looks good.
Offline Kevin D
  • SE Michigan
Re: Starter Clutch
« Reply #31 on: April 26, 2017, 06:20:53 PM »
That oil seal, does it play any part in this? Sorry for my ignorance, but what does it seal? I have a new one in the basement that I never installed, because I didn't pull the rotor when I split the cases.
25x33x4
91215-300-003
71 CB750 K1
106,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Re: Starter Clutch
« Reply #32 on: April 26, 2017, 10:07:40 PM »
Valid question about the seal, Kevin. It doesn't seal anything; it's purpose is to direct oil from the jet in the crankshaft through the bushing in the starter gear towards the crankcase side, instead of out on the alternator rotor side. When the engine is running, the stationary gear floats on the film of oil. No, it isn't related to the starter clutch issue.
Offline mcswny
Re: Starter Clutch
« Reply #33 on: April 27, 2017, 08:34:31 AM »
Was wondering about the seal earlier this week! Thanks!
1972 CB750 K2
1975 XL250
198 XR80
