Author Topic: 1976 k crank pin bearings  (Read 973 times)
Offline bomorr
    • sohc/4
« on: May 14, 2017, 02:59:41 PM »
After tearing my motor apart I am trying to determine what bearings I need to use when I rebuild it. I've done the table crank/ case and I know what it had originally but before I order $200 in bearings I want to make sure I have the right ones. After double checking my crank pins I measure a few of them at 35.095. This is way below anything on thr tables I see. Do I need to start looking at a replacement crank?
Sent from my SM-G950U using Tapatalk
Re: 1976 k crank pin bearings
« Reply #1 on: May 14, 2017, 03:08:47 PM »
What are you measuring with? I would not trust a caliper. Micrometer needs to be checked with a standard.
Offline bomorr
    • sohc/4
« Reply #2 on: May 14, 2017, 03:14:37 PM »
Yea I am using a caliper, my micrometer set is still on its way
Offline BPellerine
« Reply #3 on: May 14, 2017, 05:32:39 PM »
did you plastigauge them,you can just buy,one set of say green and brown and see where you are instead of buying all at once.bill
1978 CB 750K ard and webers
another anfob
Offline bomorr
    • sohc/4
« Reply #4 on: May 14, 2017, 06:41:47 PM »
Haven't done any plastigauge yet either, I'm picking up some sleeves tomorrow. So I can gauge where I'm at with the  Current bearings that were in the bike
Offline bomorr
    • sohc/4
« Reply #5 on: May 15, 2017, 02:16:56 PM »
Ok just went through my crank pins again and they consistently get 35.9918 or 1.417". For a minute there I thought I was going to have to get a new crank! So I should be able to go green  bearings and double check with plastigauge
