Author Topic: 77 400F Doesnt feel stabil  (Read 5468 times)
Re: 77 400F Doesnt feel stabil
« Reply #25 on: June 27, 2017, 02:17:18 PM »
cut it off w/ a dremel.  you wont need it.
Freeze your stem before seating the bearings onto it.
Freeze the bearing races you install into the neck.
Makes it go together that much smoother.
Offline tuckholladay
« Reply #26 on: June 27, 2017, 04:20:54 PM »
The stem is frozen, but my dremel is many miles away.  But I am starting to think this thing isn't coming off without it.
« Reply #27 on: June 27, 2017, 04:37:26 PM »
You can use (carefully) a cold chisel and separate the race and get it to slip off after a bit of time in the freezer.
I might try putting a dremel wheel on this drill
« Reply #28 on: June 28, 2017, 01:11:27 PM »
Does it matter which bearing pack goes in the top and bottom?
« Reply #29 on: June 28, 2017, 02:24:46 PM »
Also is this grease acceptable?
Offline Gene
  • Chat enuf you too can be a
« Reply #30 on: June 28, 2017, 02:45:21 PM »
I think the grease is fine. IIRC yes, it matters which is top and bottom - refer to the packing list and part numbers.
When you're putting the lower on you really only get one chance - so read, read, read and make sure you put the correct spacer underneath.
Others may disagree on the grease, or even methodology.  I just went through all this not too long ago.
*1973 CB750K3 (Bow)
Offline MoMo
  • Ride like you're invisible
« Reply #31 on: June 28, 2017, 05:45:57 PM »
The inner sizes are different, will only fit one way
« Reply #32 on: June 28, 2017, 06:03:35 PM »
I have never had to freeze anything.  You will need some well aimed whacks with a chisel and a punch.
« Reply #33 on: June 28, 2017, 06:54:22 PM »
+1....and a small piece of PVC tubing.  Here are all of the answers to your questions....
http://forums.sohc4.net/index.php/topic,1516.0.html
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #34 on: June 29, 2017, 10:56:10 AM »
I gave the shop tech $5 to press the lower bearing onto the fjr.
They look at you funny when you bring a "complex critical service" part to them without the rest of the bike.
« Reply #35 on: June 29, 2017, 01:57:48 PM »
I pressed it together with a threaded bar, some washers and the old lower race, ala someone else's video.  Worked like a charm.  I have it back together, now I just need to learn myself how to bleed the breaks properly.
Offline seventysix400
« Reply #36 on: June 30, 2017, 12:18:55 PM »
Looks good - thanks for posting pics. It might help someone else down the road!
Post a pic of the bike...!
« Reply #37 on: June 30, 2017, 01:45:46 PM »
Well, if anyone does see this looking for help, I think it was a success.  I still might take it down to have someone give it their professional blessing since I did disconnect the brake line to the front and the tachometer cable.
I just propped it up on the center stand and put some books and wood to support the front for taking the front fork off.  I took off the front wheel by unbolting the front fork axle holders (retorque 13.1-16.7 ft lbs).  I slid out the forks by undoing both the upper and lower triple tree bolts holding them (also 13.1-16.7 to retorque).  I unscrewed the tachometer cable at the gauge and the break line at the caliper to fully remove the front fork.
I took off the steering stem nut from the top, large nut in the top center by the handle bars.  It was 30mm so I had to go get socket.    Then I could pull off the handle bars.  I brought over the lawn mower and tied the handle bars to the mower handle so it wouldn't be hanging by the wires.
Next there is a spanner nut holding in the stem and bearings.  I got it off with some channel locks, I couldn't even find the right tool at the store.  Be ready to catch the stem and bearings when you take this off.
I used a small crowbar wrapped with electrical tape and a small sledge to pound out the races left inside the frame.  I broke the old race pressed onto the stem loose with a small sledge and three chisels very carefully.
I got the All Balls tapered bearing kit 22-1011.  Inside the box the 99-3512 goes in the bottom and 99-3511 is the top bearing.
It comes with two washers of different thicknesses.  Take the old lower race, upper race with a few bearings and some grease and measure them.  Do the same with your new lower bearing pack with the dust guard and choose the right washer to get the measurement the same within 1 mm.  My old bearing pack was 19 mm and the new one was 20 mm with the thinner washer provided.
I put the steering stem and the new bearing packs in the freezer to get them to contract a little.  I took out the stem, height adjustment washer and dust seal and pushed the two down on the stem.  Then I took the lower bearing pack and carefully pushed it down on with a chisel and hammer, making sure I only touched the inner ring of the bearing pack.
The new upper race went in very easily, I basically just placed it in and it tightened in there once the metal warmed up.
The lower race needs to be a little further up in there than I could bang it with a hammer, so I rigged up this gadget to press it in with the help of the old race.
Now you are basically done.  Grease up the bearings, put it all back together, retorque and bleed the brakes.
Went for a test ride this morning and my wobbles were gone, so I think it was a success.  Then I found a snapping turtle and helped it cross the road.
I am no expert, so please only use this as one reference and watch some videos etc.
Offline Gene
« Reply #38 on: June 30, 2017, 01:56:01 PM »
On moving the turtle or the steering bearings? :)
*1973 CB750K3 (Bow)
Offline Bodi
« Reply #39 on: June 30, 2017, 07:24:18 PM »
I tried to help a snapper and came way too close to losing a few fingers.
« Reply #40 on: June 30, 2017, 07:28:28 PM »
Yea I didn't touch it.  Just stood in the road and nudged it to the other side.  I've been seeing a bunch lately.  This one wasn't even half the size of one I saw the other day, I doubt I would have even gone near that one.  I really wanted a pic, but I was on the way to a job interview that day.
  • Holy Cow! I'm a
« Reply #41 on: June 30, 2017, 07:55:12 PM »
That pic is one for the books!  8)
« Reply #42 on: July 02, 2017, 08:40:56 AM »
The "jack stand" made with books or the turtle?!
  • Holy Cow! I'm a
« Reply #43 on: July 02, 2017, 10:19:47 AM »
Well...both i suppose
« Reply #44 on: July 02, 2017, 01:04:24 PM »
There was wood in there too.  Really bad idea?  It never felt like it was going to fall.
Offline jonda500
« Reply #45 on: July 02, 2017, 03:56:30 PM »
I have stopped to rescue a turtle before, don't think we have snapper turtles here, but I really regretted helping this one off the road cause it bloody pissed on me and it took days to get rid of the stinky smell on my hands!
I once successfully used my helmet to prop up the front of my bike while I took the wheel in for a new front tyre...
John
A starter clutch thread:
