Author Topic: Honda cb350f top speed  (Read 13079 times)
Offline Scooterhead
« on: July 02, 2017, 12:27:25 PM »
After completely rebuilding my bike I and curious as to what is the expected top speed
I recond my engine set valves set the point and timing and the tuning is now somewhere near
I have tan spark plugs at idle and full throttle,and I have 150 psi compression on all cylinders
I have seen Honda specs saying that the top speed is around 98 mph but can acheive about 80 to 85 mph which is probably about 8k rpm in 5th gear,is the claimed top speed correct or optimistic
Offline carnivorous chicken
Re: Honda cb350f top speed
« Reply #1 on: July 02, 2017, 01:05:02 PM »
I think 98 is optimistic on the part of the Honda engineers. I've had a 350F for 20 years, and don't ever run it flat out. It'll hold 75 easily, and do 80 just fine with a little more to give. Doesn't really answer your question, but maybe downhill with a tailwind you could top out at over 90...
« Reply #2 on: July 02, 2017, 01:06:31 PM »
Is the bike in stock configuration?
Tires?
Sprockets?
Intake?
Exhaust?
Are you in tuck to minimize air resistance?
I could get to 98 with a stock 305 Honda, but only in tuck.  I weighed 145 lbs at the time.
Offline grcamna2
« Reply #3 on: July 02, 2017, 01:19:25 PM »
Aw come-on,according to member JWilde we can spin up a CB350F to 85mph in 2nd gear !  :D  ::)
75' CB400F/'bunch o' parts'
Offline MoMo
  • Ride like you're invisible
« Reply #4 on: July 02, 2017, 01:21:38 PM »
That's right, Bill.  I still plan to race against him with my 400 Seca, which has been clocked faster than 85 in 2nd              Buy a bridge anyone??
« Last Edit: July 02, 2017, 01:24:49 PM by MoMo »
« Reply #5 on: July 02, 2017, 01:22:27 PM »
I was gonna add that but you beat me to it!
Offline grcamna2
« Reply #6 on: July 02, 2017, 01:24:01 PM »
lol  ;D  one might wonder how high he was..
Offline Scooterhead
« Reply #7 on: July 02, 2017, 01:34:57 PM »
Bike is completely stock apart from the guy I bought it from fitted 4 to4 stainless exhausts without baffles(loud)
What am i missing here it's a total recond engine new piston rings etc.struggle to get more than say 82mph but that wasn't tucked in
Oh and I am about 105 kg
« Last Edit: July 02, 2017, 01:42:54 PM by Scooterhead »
« Reply #8 on: July 02, 2017, 01:44:39 PM »
Probably needs bigger main jets for that pipe.
Offline Deltarider
« Reply #9 on: July 02, 2017, 01:46:37 PM »
In tests they usually gave the top speed 1. sitting upright and 2. nose between the meters (and sometimes 3. riding two-up). Makes a big difference.
CB500K2-ED Excel black
Offline Steve_K
« Reply #10 on: July 02, 2017, 03:44:10 PM »
I would also question whether the speedometer is accurate.  40 years ago speedos sometimes were off when new. I recall my 350 twin had trouble breaking 80 mph on the speedo.
Steve
Steve_K
« Reply #11 on: July 02, 2017, 03:59:35 PM »
Steve
Very good point about speedometer accuracy.  My 305 was 3 months old when I did my max out runs.  But, it was 98 indicated, right in front of my face.  Very slow to rise after 95.
I would think a 4 cylinder 350 would do at least as well.
« Reply #12 on: July 02, 2017, 04:15:53 PM »
IIRC, the redline for a 350 four starts at 10,000 RPM. Try taking it up to redline in forth gear before upshifting.
Offline Dracon
  • Wannabe Old Timer...
« Reply #13 on: July 02, 2017, 05:32:53 PM »
 Another possibility could be as simple as power to weight ratio. You currently way just over 230 pounds and I'd be willing to bet the average weight of the Japanese test subject in the 1970's was closer to 160 pounds. If you lost 70 pounds I bet you could  get a decent amount faster than what you are now.
Please don't take this to say that I think you are overweight or should lose weight,  I know nothing about you, your height, your build, or anything… just that the average weight of the test subject when the top speed was taken was probably less.
Offline grcamna2
« Reply #14 on: July 02, 2017, 09:19:07 PM »
I'd like to see the spark plug color,if white in the center porcelain I'd richen-up the main jets considerably  :o
« Reply #15 on: July 03, 2017, 06:52:33 AM »
+1
75s are too small.  try 78s(if you can find them) or 80s
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #16 on: July 03, 2017, 08:35:33 AM »
The horsepower gain/weight reduction diet is something everyone oughta try at least once.
« Reply #17 on: July 03, 2017, 08:49:52 AM »
I religiously drop 2lbs before every ride  :o ;D
  • Holy Cow! I'm a
« Reply #18 on: July 03, 2017, 10:42:23 AM »
It's 14# per horsepower ain't it?
« Reply #19 on: July 03, 2017, 10:57:18 AM »
FML....I though it was 14hp per lb!   :P
« Reply #20 on: July 03, 2017, 11:05:58 AM »
Depends on how fast you want to change the inertia of the mass.  And the rolling resistance, and the air drag.
Here's a chart mapping the HP needs vs speed of a Honda 350 Motorcycle.
Offline Scooterhead
« Reply #21 on: July 04, 2017, 10:22:40 AM »
Can't quite make it out
How much horse power for the claimed 98mph then
Offline robvangulik
  • Honda Fourever
« Reply #22 on: July 04, 2017, 10:56:31 AM »
About ten HP more than Honda claims it has  :P  ;)
Offline markreimer
« Reply #23 on: July 04, 2017, 02:31:36 PM »
My 74 350F topped out in a full tuck with no wind (or maybe even a minor tail wind) at about 95 according to my speedo. It was probably exaggerating the speed, but a friend riding with me figures he was going about 155km/h, which is 96mp/h. I weight 150lbs and had a little 6" wind screen I was tucked behind. With a bike this small, weight and aerodynamics really matter! The second I lifted my helmet above the screen my speed would drop by 4-5 mp/h. If I sat up straight, I'd drop a good 10 or more.
Eventually I had to rebuild the engine due to excessive oil burning, found two pistons with heavy scarring on the sides. Hone, new rings, valve job, and my top speed was actually LOWER than before, despite even compression. Then my #4 cylinder gave up the ghost and filled with oil. Still haven't gone back into the engine to fix whatever happened.
Offline Scooterhead
« Reply #24 on: July 05, 2017, 01:15:10 PM »
I was tucked in today and got 85 mph I weigh about 107 kg
I did a plug chop as well the first one is at full throttle and the second is at idle
Here is the pictures ,what are your opinions
« Last Edit: July 05, 2017, 01:17:10 PM by Scooterhead »
